Is no muffler bad for your car?
Been hearing that mufflers provide down pressure or something of sorts to help the engine and with out the mufflers the head will dry out head not headers. Anyone know anything about this?
Mufflers do add back pressure to to the combustion system .
I dare say the modern car engine is designed to give optimum performance with this back pressure.
Some have said that lessening the backpressure can burn exhaust valves.
I would say that this would not happen overnight!
And, it's backpressure.
If the system is too short, the fast moving pulse will collapse as it exits the end of the pipe, and the low pressure wake will also collapse, reducing the scavenging effect, especially at low RPM. This will be felt as a decrease in performance right off the line.
As RPMS increase, the speed and frequency of these pressure waves increases, negating some of the performance losses and restoring the scavenging effect.
Exhaust scavenging is a function of velocity, not backpressure. Having lower backpressure is a good thing. If a modification decreases the velocity, then a low RPM power loss will be the result. In the case of cutting off the muffler and not at least replacing it with a straight pipe, this modification is reducing the opportunity for the exhaust to built up and keep the speed, and it instead slowing down the exhaust as it exits, creating more backpressure than the stock muffler.
An x-pipe creates a cross flow which allows the pressure waves to accelerate each other and create a positive induction.
If you replace your muffler with a piece of pipe, you will get the sound you are probably after without loosing the velocity that is essential to produce power.
Now I ask you, does this make sense?
Even carbureted engines operate this way although jets have to be changed to supply more fuel at high rpms.
The Porsches I owned with Weber triple throat carbs were modified with larger venturis which meant larger idle and main jets. But, enlarging the venturis meant a loss of low end torque. It's a tradeoff.
And, 4-valve heads without variable intake cam timing also costs low end performance.
I opened up the exhaust and intake on my old school carburated bike and was running way to lean. If I wouldn't have rejetted, I would have fried the valves within 1000 miles.
and i drive it a LOT!
