Stems leaking/cracked on TPMS
Anyone heard of this issue before:
Front right tire was leaking, took to tire shop, and they stated that stem is cracked, need new TPM sensor, then 3 weeks later, the front left tire loses air and same issue? TPM stem cracked. I asked what would cause this and they said that freeze/thaw may cause it or simply "age". I am not sold on this theory yet. Searched the forums and couldn't find an answer. Any help would be greatly appreciated. Car is out of warranty so it will cost me $150/a piece to replace unless anyone knows of any other sources.
2011 C300 4MATIC
I'm glad I don't have TPMS in Canada. I have it on my Wife's Infiniti and it's a pain in the *** getting the dealership to reset the sensor light each time I switch winter and summer wheels.
Cold weather changes really should not be causing the TPMS to fail structurally.
'09 C300 Sport (Manual)
Try the Tire Rack, I think they're cheaper for the sensors. Don't remember quite what I paid but the extra set of tires for autocrossing were about $78 each and the sensors were a little less than this.
SPONSOR/MBworld Guru
Something you should know about OEM MB TPMS and is fairly well known among aftermarket wheel shops that deal with a good chunk of MBs.... The TPMS sensor has the rubber seal inside what can only be described as a cup shaped holder. As such, the amount of usable rubber that extends past the lip of the cup is actually very tiny and can very easily lead to improper seals. What most good shops will do is sand down the lip of the cup so you have more exposed rubber and can more tightly seal the TPMS in. Keep this in mind as most crap shops will just blame it on a cracked TPMS sensor instead of really getting down to the root of the issue.
Thank to all for the info and especially AZN.....I will see if I can find a good shop to look at this and do for me.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Dismal seepage
Over time the sealing o-ring (inside) will shrink a little.
This fixed my sudden leak last year and it has not returned.
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
FYI, torque for the nuts on the TPMS stems is 8ft/lbs - so don't tighten them too much. You can also order stems separately from the sensors.....
