Anyone lowered on 17's?
Old Mar 4, 2011 | 12:18 PM
dewydang's Avatar
C300
Anyone here lowered on 17 inch rims? Or stock 17 inch rims? or will i be the first ? If you do, pictures please
Old Mar 4, 2011 | 12:21 PM
jctevere's Avatar
2012 C250 Coupe
Am I the only one that doesn't get the whole "lowering thing"... I think the car is already low enough to begin with. I scrape the front bumper just going in peoples driveways. Lowering it any further would be a pain in the ****. Have to watch out for everything. The distance between the outer edge of the tires and the fender isn't even that big stock... I have definitely seen much worse.
Old Mar 4, 2011 | 12:42 PM
Sportstick's Avatar
Another round of ICE
No, you are not the only one!
Old Mar 4, 2011 | 01:32 PM
ambit's Avatar
09 CLK550
Mercedes has sold over 1 million W204's.. but I'm sure you'll be the first to lower it on 17" rims..
Old Mar 4, 2011 | 03:30 PM
dewydang's Avatar
C300
^^ very true
Hahaha. hows the fitment look? not to bad right?
Old Mar 4, 2011 | 03:58 PM
Sportstick's Avatar
Originally Posted by dewydang
^^ very true
No....I was responding to jctevere! I don't get the "lowering" thing either!!
Old Mar 4, 2011 | 04:00 PM
Matt_Eurojerks's Avatar
w204 C300
If you are hitting things stock then you need to learn how to drive a low car. You should never rub anything. It's all about the angles and going slow. I feel like our cars are a mile off the ground when I look at it.
Old Mar 4, 2011 | 09:15 PM
dewydang's Avatar
C300
Do you have any pictures sportstick?
Old Mar 4, 2011 | 09:51 PM
Sportstick's Avatar
Of what? Re-read my post above please!
Old Mar 5, 2011 | 12:19 AM
zankok's Avatar
W204, W220, S15 Silvia
lowering on stock 17's will emphasize the crappy offset even more, better plan it with some spacers first, i think eibach with 5mm spring pad gives the optimum ride height for a daily driver
Old Mar 5, 2011 | 12:59 AM
itsLoonie's Avatar
2012 E350 RWD
^ True that.
Here's pictures of someone on springs on 17s.
https://mbworld.org/forums/c-class-w...k-springs.html
Old Mar 6, 2011 | 05:24 AM
dewydang's Avatar
C300
doesn't look as bad as i thought hahah.
I have an extra set of 17 inch rims that i might as well put them use.
Old Mar 6, 2011 | 10:01 AM
Acapulco Bill's Avatar
2010 C300 Sport
The lowering thing - yesterday I scraped the bottom of my C300 around 40 times just driving over speed reducers (and this going as SLOW as possible, alas they were taller than the low point just behind the front axel). So hey, I DON´T GET IT EITHER!!!
Old Mar 6, 2011 | 04:34 PM
Will38's Avatar
2008 C300
I lowered my car for over a year and half and now my car is mess up from the underneath. I scrape over everything you can think of, and yes I'm running on 17" with 5mm. I think it would be better to have 18".
Old Mar 6, 2011 | 05:27 PM
Sportstick's Avatar
With 18" tires, you would have a lower profile tire with a similar overall diameter of the wheel/tire unit, your car would be just as low, and you would incur just as much damage.
