Best Type of Brake Pads to Buy?!?!?!
Subscribe
Mar 22, 2011 | 08:19 PM
Quote: Hmmmm...design difference could be a side effect of a local supply base. Perhaps the next step would be for your MB Parts Advisor to check part numbers for pads in Malaysia versus North America to see if the OE parts are different.
Thanks for your help,will try to get more info..btw, actually mine is a parallel import UK spec car...
Reply 0
Mar 24, 2011 | 07:28 PM
With 39k almost coming up, I want to change the front pads with aekobono pads. For those of who has, did you guys change rotors as well, if so which one?
Reply 0
Mar 26, 2011 | 03:39 AM
Axxis got some really good brake pad as well. very low brake dust
Reply 0
May 25, 2011 | 12:16 PM
Prices?
Reply 0
May 25, 2011 | 12:22 PM
On Amazon, about a total of $150 for the EUR 1340/1341 fronts and rears, purchased separately.
Reply 0
May 29, 2011 | 10:15 PM
hmmm wonder how these compare to the ebc red pads.. the akebono are a little bit more thou
also you dont have to change your rotors... rotors should be able to last ya over 100k miles i would think.. all the past cars i never changed the rotors and when i sold the audi it was at 130k and still rotors were still good..
Reply 0
May 29, 2011 | 10:24 PM
  #32
Quote: With 39k almost coming up, I want to change the front pads with aekobono pads. For those of who has, did you guys change rotors as well, if so which one?
I put them on three cars, did not change rotors on the two MBs...the third one already had some pedal pulsation due to rotor warpage, (not a Benz), so it got new rotors from Ate.
Reply 0
Apr 2, 2013 | 12:33 AM
  #33
where can i buy pagid black/blue for w204 c300 oem calipers? need more bite.
thank you
Reply 0
Explore
Sep 3, 2015 | 07:59 AM
  #34
Hi everyone,
I was trying to find threads closer to my issue/concern, but I could not.
I own 2011 C300 4MATIC. Currently it has 53K miles, and I believe the rotors and the pads are original.
I started to feel a slight pulsation when I am breaking. The steering wheel shakes; not crazy, but enough to notice. The quicker I have to stop the stronger the pulsation. I noticed that the front rotors have some lines/grooves, see pictures.
My questions:
1. Is it worth reworking the rotors? If anyone has gone this route, what are the costs?
2. If rotors can/should be rework, what about existing pads? Should they be replaced or something can be done to fix this?
3. Should I just replace the rotors and pads? How much money should I be looking to spend?
4. What are your recommendations?
Thanks for your help!
-Vadim
Best Type of Brake Pads to Buy?!?!?!-2015-09-01-16.52.05.jpg   Best Type of Brake Pads to Buy?!?!?!-2015-09-01-16.51.37.jpg
Reply 0
Sep 3, 2015 | 10:33 AM
  #35
Replace them. You will find the front ones are pretty close to be worn out. The rears should last until the next pad change.
Reply 0
Sep 3, 2015 | 04:26 PM
  #36
Go to ECS Tuning they have kits for just the fronts or all four wheels. Those rotors can't be turned they look like the grooves are to deep. It's easier to replace the rotors and pads, it's an hour to two hour job taking your time. Has the sensor gone off yet? I know when my front pads went the sensor went off and I got maybe another two hundred miles before they were toast.
http://www.ecstuning.com/Mercedes_Be...enance/Brakes/
Nelson
Reply 0
Sep 10, 2015 | 07:51 AM
  #37
Quote: Go to ECS Tuning they have kits for just the fronts or all four wheels. Those rotors can't be turned they look like the grooves are to deep. It's easier to replace the rotors and pads, it's an hour to two hour job taking your time. Has the sensor gone off yet? I know when my front pads went the sensor went off and I got maybe another two hundred miles before they were toast.
Nelson
Hi,
Nope, the sensor has not gone off yet. As far as grooves - they are not that deep as it might look on pictures. If I go across them with my fingers, I barely feel them. What might be the cause of those lines/grooves?
Thanks for your input.
-Vadim
Reply 0
Sep 10, 2015 | 03:10 PM
  #38
Why don't you take the caliper apart and see if there is some material stuck to the pad. Then you can re-seat the pads and see if the lines go away. And give the rotors a quick wipe with some brake cleaner. The lines could just be glaze so maybe a re-seating of the pads might just do the trick.
Nelson
Reply 0
Sep 10, 2015 | 08:45 PM
  #39
A close up look at those rotors show a lot of wear. If they are worn away by 3mm or more they are toast. Spend a couple of hundred on new rotors and you cant go wrong
Reply 0
Sep 11, 2015 | 12:56 AM
  #40
I just installed HAWK Street performance 5.0 on mine.. had them for 2 weeks.. Still very very little dust.. Seems to brake really well especially when they get hot !!!
Reply 0
Sep 12, 2015 | 08:06 PM
  #41
My theory on why some of us get grooves on our rotors.. the Mercedes rotors (and some other aftermarket rotors) are "soft". The low dust brake pads are often made with hard material, that is why the "hard" pads are eating soft rotors.
Grooves aren't a good thing to have on our rotors.
I have a Jeep Grand Cherokee with four disc brakes, I bought Stillen brand rotors (cross drilled) and pads. After 7,500 miles on them, the rotors are in excellent shape. The rotors (braking) surface looked so beautiful and flat. No grooves. That's because both are made for each other. The stopping distance with Stillen brakes are better than OEM.
I think Stillen makes some brake rotors and pads for W203, not sure about W204. You can check Stillen website to find out if they will fit your Mercedes. They were made in America. I understand that other brands (aftermarket) like Centric were made in China. I'm not too sure about PowerStop...I think they were made in China, too. Ugh.
My wife's W203 brake rotors have grooves. Someone installed aftermarket pads and they are terrible. I plan to replace everything by myself using Mercedes-only brand rotors and pads. I have a W204 with Mercedes-brand rotors and pads installed by Mercedes dealer in Escondido and surprisingly, I have near-ZERO brake dust on my wheels. I'm really happy with them!!
Reply 0
Mar 23, 2018 | 03:34 PM
  #42
Reply 0
Mar 23, 2018 | 04:05 PM
  #43
Reply 0
Jul 6, 2019 | 04:52 AM
  #44
Break Pads Option in india for Merc C Classs
Are Brembo Break pads comparable to the OEM for c Class Merc. There is a huge price difference if we get them replaced with the authorized dealer VS Brembo....Any Suggestions...
Reply 0
Jul 7, 2019 | 12:33 AM
  #45
I thought I'd put this up for Australian owners wh might be thinking of changing brake pads after market pads
I recently bought a set of Bendix Euro + pad for my MB W204. $55 ( $75 at supercheap) for a set of 4 fronts From Sparebox. The pad wear sensors for $2.50 each from repco.
https://www.bendix.com.au/product-range/euro
Brake Pad is DB 2181: https://www.bendix.com.au/manufacturer/ ... sedan-w204
Sensor is : https://www.bendix.com.au/manufacturer/ ... sedan-w204
There was only one sensor for the drivers side- I got it form Repco for $2.50. Spares box was over $20, Supercheap $7.50
The pads from spares box were $53 delivered ( Supercheap $75, Repco $135).
https://www.sparesbox.com.au/part/bendi ... b2181-euro -Price has gone up compared to 10 days a go!
The kits comes with 4 spring clips and 4 bolts. Torque settings: caliper to steering knuckle 180nm, bolt for ant-rattle spring 30 nm, bolt of rbrake pad sensor to caliper 8nm
Easiest brake pad replacement I've ever done. 3 bolts two clips per wheel, one sensor on drivers side ONLY ie passenger wheel has no sensor.
Ive already done 200k km's and they perform ( braking distance, feel) at least as well as the genuine mercedes pads, NO squeels ( the merc pads did).
Interesting to see how they go for brake dust on the wheels- the genuine merc pads were terrible with that.
Oh yeah and Amoural break dust repellant works, for a while
Best $50 car parts I've ever bought.
Reply 1
Subscribe
Currently Active Users (1)
