tire puncture found after delivery
When I bought my new C in Dec, I also bought a set of winter tires and rims, and I had the dealership mount the winter set for delivery - I've never driven the car with the originals. (AMG 18s)
Well, I was about to switch sets this weekend - it turns out there's a screw embedded in one of the new tires. Through the contact patch area, not the sidewall. I started taking the screw out but stopped when I heard hissing.
This could only have happened before delivery, during PDI.
What's a realistic resolution? Just having it plugged? Is that safe and permanent? Having the dealership pay for a new tire?
2009 C300 Luxury P1 w/Multimedia, Arctic White
Plugs are pretty cheap to have done. But since it's a brand new tire, I'd kindly ask the dealership for a new one. Since they mounted the winter tires before you took delivery, they should have record that those tires haven't been used by you....unless you've already mounted them.
2012 C250 Coupe
I would try the dealer, explain the situation, but IMO, prepare to bend over and get raped... Sorry to hear your situation, hope it works out for you.
You can plug it and it will be absolutely fine. But to appease those that will argue with me until their face is blue, they will say it is dangerous and a bad option. To which I would also recommend bringing it to a tire shop and having them unmount the tire from the rim and patch it from the inside. Costco does this - for a fee, but its not much, definitely better than the cost of a new tire, and considering yours is truly new, I would try this route.
But of course, try the dealer first, you never know...
A good dealer should take care of you with this one. It's pretty obvious the screw didn't get shoved in there while sitting in your garage so hopefully common sense and customer service will rult the day!
Mercedes Benz C300 Sport
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
A tire that is plugged is not properly inspected for internal damage. The action of plugging the tire further exacerbates the problem of the puncture itself. It can absolutely be considered dangerous and a bad option. But as you say in the next sentence, getting it patched is the proper method. This is approved by the Tire Industry Of America, and The Rubber Manufacturers Association. And even better, it still allows the tire manufacturer to cover the tire should it ever have a warrant-able failure.
