W204 Brakes Fail Roadworthy - Benz Says Normal!
#76
Considering the low failure rate of this assembly I doubt they'll do anything with it except pass it on to the vendor. If a human maintenance error caused the problem I think we'd see more failures than this one. I believe it was a component failure. I never doubted it would be resolved but I'm very surprised at how long it took and the effort required on the customer's part.
#77
Super Moderator
Thanks for the report Glyn.Good news.
Do you think MB will do an analysis of the HCU?
I might be an idea to open the calliper bleed v/v when pushing back the pistons to stop any chance of overpressurisation & dirt entering this complicated system ?.
Keith certainly has had his problems with this 220cdi . I liked the story of the 2005 C Class 220cdi with over 500,000 Km on the clock.The owners comment for such a high virtually trouble free mileage was to "treat her like a lady"!
#78
Super Moderator
#80
Super Moderator
Yes - The ABS unit on this car is ATe & was replaced with ATe.
#81
C280 2007 4matic
like i said in post 27 ...
i see this trouble in ATE abs before in a mustang 2006 !!! plug the master cylinder and pedal wont go to floor, pressure test front and rear calliper, if all ok, replace abs module.Mercedes have ATE abs in my c280 2007.
Yvan
Yvan
#82
Super Moderator
Yes - thanks Yvan - we took your input into account along with others.
#83
04' C230Kompressor Sports Coupe A/T
Brake Problem
Hi Guys,
Im new to this forum and I have encountered the same problem except on my w203 sports coupe. Itsa out of motorplan and have had it at a mechanic numerous times and the probelm still prevails.
Any solutions???
Can anyone help.
Any solutions???
Can anyone help.
#84
Super Moderator
If the whole system is sound then replace the ABS block.
#85
Very interesting I'm having the same problem I can't bleed my brakes, can't seem to get a firm paddle always sinks to floor I have replaced the mc and servo, I have pressure bleed it I have manually bleed it, I have plugged in to star because apparently you have to use star to bleed nothing I can't get a pedal I'm going to change the abs unit and try will update if fixes the prob.
Cheers
Cheers
#86
Super Moderator
Please let us know the outcome. The likely offender is the ABS block.
#87
I ended up replacing the abs unit and that changed nothing. In the end I put all the old parts back, pressure blead the system twice and voila it all worked. So still don't know what the actual problem was.
#88
Super Moderator
