- Mercedes-Benz C-Class: How to Replace Cabin Air Filter
Step by step instructions for do-it-yourself repairs
Browse all: Interior Guides
Cleaning Cabin Air Filter.
I have blown our the large particles but the fine pollen/grime is not removed by air.
Does the filter material break down with gentle water & detergent washing?
My Kubota tractor has a washable engine air filter . The material seems similar. The MB filter has a slightly glossy fibreglass appearance.
Enjoy your Easter.
Enjoy your Easter.
I am due for service B right now. Exactly what is involved and is it worth taking it to a stealership or can a knowledgable novice do it?
Have a good light in footwell.
1. Remove protective carpet ( if any) & cabin bottle holder mesh pocket.
2.Remove 3 tork screws at rear of cover.
3. Now the difficult to see part. Unclip plastic catch( large plastic clip) which is in the middle of the underside of the plastic cover.
4. Remove small electrical connector .
5. Carefully wriggle cover out which exposes access to rectangular shaped filter.
6.Unclip metal clips from each end. I used a long pointy knife.
7. Slide the clever white plastic holding carrier clip to the disconnect position.
8. Withdraw filter. It will only go back one way.
Good luck.
I would be interested to know what a new replacement filter costs in the US. I reckon it will be well over $100 here in Aust.
I have spent 15 minutes with a compressed air nozzle blowing off a light accummulation of fine material from the filter. It looks to be measurably cleaner. After reinstalling it into the car there is ample air flow at the #3 & 4# settings. A hurricane at full setting. I will try using compressed air & a vacuum cleaner nozzle next time.
Absolutely no reason to replace with a new one this time.
$18.80 US last month when I changed mine for the second time.
Today's price is $16.58.
The same exact MANN filter that the US dealers sell for $60.00+.
I do like to clean the housing once I have the filter out, but other than that, don't bother cleaning the filter--get a new one once a year and put it in yourself. No point in cleaning these things.
https://www.mann-hummel.com/mf_prodk...u/HBYyDKP4.pdf
Enjoy your Easter.
