Need advice on buying mufflers.
Just got a xpipe installed, and would like to get new mufflers do the quad exhaust.
Anyone know which stainless steel mufflers i can get that will fit on the c300
dont care i the mufflers have 1 exhaust port or 2, cause ill just get a Y pipe done for the quad tip.
Mercedes Benz C300 Sport
But if you want to replace the muffler with a true quad tip such as Eisenmann or Meisterschaft then you don't need to fabricate a Y pipe. If you want a less expensive alternative you can go with Magnaflow.
I wanna replace the mufflers cause the stock ones just destroy the sound of he magnaflow xpipe. But I'm not allowed to do a straight pipe cause that will go passed my "loudness" law here in Calgary, Alberta. So I'd like to remove the current ones and replace with new ones that give it a meaner growl. Dont wanna spend too much. And like I said before if the new muffler comes with 1 exhaust I'll fabricate a Y pipe for quad tips but if the new
Muffler is built for quad tip that's cool too. Also. Anyone know the sizing of exhaust tips. I don't wanna keep the oval looking Mercedes tip. But get black painted circle tips. Thanks
Prices are pretty standard across the board unless you purchase it used.
Meisterschaft is around $2000 for the quad exhaust + shipping/taxes/ installation costs
Eisenmann is $3,200 + shipping/taxes/installation costs
Check out tanktube's Magnaflow exhaust set up... It's neat looking without spending $$$$
I dont need Meistershaft cause thats the whole exhaust setup right?
Ya i msge'd tanktube about the magna flow setup, he didnt tell me which part though lol
ima go to tunerworks and ask them what they got for me.
Just looking for a cheap muffler replace that would drown the sound like the stock ones do, and if they are stainless steel thats good.
Anyone know where i can buy good exhaust tips.
and what size do i need?
i just got magnaflows, i didn't like them until i got an xpipe but you have one already so it should be fine, just remember the smaller the muffler the louder they are, the magnaflows wont be abnoxiously loud, its a nice loud though i'll post a sound clip soon
you can find used magnaflow mufflers for like 60-100 but you'll need two, and magnaflows have lifetime warranty
I noticed that the inlets and outlets are 2.5" instead of 2.25", and I searched the Magnaflow website, and it seems that that's the only size they have for the 4"x9" oval same-side design in the right length. Will this be a problem if I intend on using the stock tips?
Also, how do Magnaflow mufflers compare to straight pipes?
Im wondering the same thing richard
i know my xpipe is 2.25 so will 2.5 work?
and do i want a same side offset
or center to center>
cause i dont know how the quad tip will work?
will it be a straight Y pipe or curved?
K so what size of exhaust pipes do i get??
ill go with 2.25" IN, but what about the length???
the muffler im going with is part # 11376 and exhaust # 35168
*go to magnaflow and enter those numbers to see parts*
will that combination work??
'11 C350 '13 F150 lariat
I have the magnaflows and the magnaflow quad tips on my 350. I used the 2.25" and the quad square rolled tips. I got them for alot cheaper than advertised. I went polished stainless looks better. The exhaust shop will expand both sides of the mufflers for slip on to stock exhaust pipes and the tips. I will tell you that Im removing the magnaflow tips tho. I searched for days for a staggered setup and all I could find is one by Corsa. they are not wide enuff to fill the C63 diffuser tho. Im gonna have to get 4 tips and fabricate a proper tips for these cars. If you dont have staggered tips one is flush and the outside one is 1" plus out of the rear, doesnt look bad, but not what I was looking for. If you need the part #s I can get them for you and where to order cheap. I got the smaller ones and its got a nice growl, its def louder than stock. smaller muffler more noise. See how small teh meisterschafts are compared to stock, half the size
heres teh pics to my magnaflow setup
https://mbworld.org/forums/c-class-w...-new-whip.html
14375 is the muffler
35170 is the tips I used
my other choice of tips I liked was
35169. no matter what tips you use its gonna stick out on the outside cause the bumper is curved
