Anyone remove the chrome strips that are on the doors? (the thin ones at the bottom)
On my car, floss kept breaking every two inches, so I switched to using a spackle knife with painter's tape on the end. Talk about easy. Each strip literally came off in a couple mins by slowly pushing the blade with one hand while pulling the trim with the other. You need to have polish and quick detailer handy to get rid of the outlines from the embedded dirt over time an washes.
Since my car is black, it's quite a noticeable change. Will post pics later as well as respond to the other thread about the window trim.
After:
DocTodd - your car being 100 miles young is a good thing, but with rail dust, etc, I'll bet you'll still need to do a little bit of polishing. Either way, no big deal for a mod that changes the entire look of a dark car.
Window trim was done with Trim Brite from Amazon. Can't beat $5/roll. Two rolls are required, and you'll have lots left over. I covered the trunk strip as well as re-did the rear passenger door since I wasn't happy with the results (was the first strip I did, so was the experiment door). Will post close-up pics to the other thread so as to not double post.
After:
1. Is the tape wide enough to cover the whole top trim in one piece when the door is open?
2. Does it peel off when washing the car?
I think the chrome strip was originally designed for the luxury model. There's another chrome strip on the rear bumper so the strips "flow" and go around the car. MB probably just left them on for the sport models due to the manufacturing and supply chain procedure.
Most people probably don't care for that strip anyway. Just us enthusiasts
Trick is to spend time getting the vinyl to line up perfectly to the top of the trim strip, then seal the rest by working down. Let the excess actually stick to the door paint. Now use your *finger nail* to crease the vinyl along the gap between the trim and the door panel. That provides you with the guide for the xacto. When cutting, angle the knife UP into the crease vs straight down into the door panel. That way, you can use as much pressure as you want because the knife is going up into the cavity of the trim so you're not damaging anything. After the excess is off, go back and fold the flap down and into the gap between the strip and the door to seal it all up.
I was beating myself on the head after doing the other three doors perfectly w/ this method.
http://cgi.ebay.com/ebaymotors/ws/eB...m=180645538308
The Chizzler I think it was called. works like a champ.
