kleeman ts 7 19x10? help please!
Old May 3, 2011 | 08:47 PM
mbcoolguy's Avatar
c300
hi guys. im about to get a set of kleeman ts 7 for my c300 luxury. i plan on dropping with h&r super sport springs. should i run 19x8.5 all around or can i go 19x10 on back? if yes what tire size without issues? thank you
Old May 3, 2011 | 11:16 PM
Matt_Eurojerks's Avatar
w204 C300
All about the offsets.10 is not huge but with a low offset it will be a pain to not rub if you don't stretch the tires a bit.
Old May 4, 2011 | 07:10 AM
mbcoolguy's Avatar
c300
sorry i forgot to list offset. 19x8.5 et55 19x10 et60. i really hope it fits because i really like the staggered setup.
Old May 4, 2011 | 10:05 AM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
ur gonna have to run spacers w that setup. Im runnin 8.5 up front and 10 out back. 275/30/19 in rear w 40mm offset. they stick out but clear on bottom outs
Old May 4, 2011 | 12:00 PM
mbcoolguy's Avatar
c300
what size spacers do you think ill need? for the back only? what tire sizes do i need for front and back. thank you for the replies.
Old May 4, 2011 | 12:44 PM
w204 C300
This is a 255-30 on a 10.5 ET 48 (a bit of stretch)
Old May 4, 2011 | 12:45 PM
w204 C300
Post pics for him...
Old May 4, 2011 | 01:00 PM
mbcoolguy's Avatar
c300
that looks good matt. what springs do you have?
Old May 4, 2011 | 01:02 PM
mbcoolguy's Avatar
c300
maybe i might go 18x8.5 all around dropped on h&r super sport. i wish there are pics of 18s on super sport.
Old May 4, 2011 | 01:25 PM
i will post pics 2nite. Matt is the one who helped me with my rim size i was gonna go 9.5 like my last car but I went 10 and it looks sweet. I have a tiny bit of stretch, i woulda tried 285 but I tried the 275s first and they just made it. I can fit a piece of cardboard in between when bottomed, my last rims were 35mm offset 18s and I tried 265 on a 9.5 and it rubbed, so I went 255 and it clared but slightly rubbed the felt inside on bottom out but no probs. I have 235/35/19 w 45mm on front and 275/30/19 on back 40mm and I clear. Your gonna need spacers to clear on the inside and for brakes, and push the rims to the outside, otherwise it wont look good, you want a WIDE stance
Old May 4, 2011 | 01:42 PM
mbcoolguy's Avatar
c300
thanks jimmy for the info. looking forward to seeing your pics.
w204 C300
It's 08red350 car.
Old May 4, 2011 | 01:46 PM
w204 C300
10mm up front brings you to final ET 45
15mm in back brings you to final ET 45
I personally think that would look great. If you want to be a bit more conservative you can do 8mm and 10mm
Old May 4, 2011 | 02:07 PM
mbcoolguy's Avatar
c300
matt do you think that will be ok on h&r supersport? and what tire sizes? thanks for the knowledge.
Old May 4, 2011 | 02:10 PM
mbcoolguy's Avatar
c300
i forgot to state that this is for wifey. so im looking for no problems. thanks
Old May 4, 2011 | 03:27 PM
w204 C300
1) :thumbup: on wifey rolling LOW.
2) I would just go 8mm and 10mm then so it doesn't rub on the outside rear quarter panel
3) 245 up front and 265 on the back
Here is a 245 on a 8.5 ET 48 Front
Rear is 9.5 et50 275 rear
Old May 4, 2011 | 05:13 PM
mbcoolguy's Avatar
c300
thats hot bro! what springs you have? 5mm pads? i love that stance.
Old May 4, 2011 | 05:22 PM
mbcoolguy's Avatar
c300
or should i get h&r sport? im getting a headache.
Old May 5, 2011 | 10:09 AM
w204 C300
That is not my car. Its KW V3 coilovers though.
Old May 5, 2011 | 10:12 AM
mbcoolguy's Avatar
c300
ok so ive decided to go 18x8.5 et55 all around. what spacers do you think i should go with to for the most aggressive look without issues and what tire size all around. sorry for being so complicated.
Old May 5, 2011 | 10:34 AM
w204 C300
So I am thinking you need to space the front out to at least the mid 40's (see above pic) that 245 looks good on that wheel with that offset so go with that.
For the rear you have options (different size spacers 8mm, 10mm) on how close you want the tire to come to the rear quarter. With a 8.5 there will be no rubbing issue on the inside, but if you start to get close (using spacers) on the outside of the QP then there might be a small risk of rubbage if you are really low and hook a turn to quick or hit a big dip on the highway. Thus is life with lowered cars. I would do 245 in the rear as well to make it easy.
Old May 5, 2011 | 10:35 AM
w204 C300
Check out this thread for better "look" at different setups.
https://mbworld.org/forums/c-class-w...ts-wheels.html
This car is nicely done
https://mbworld.org/forums/c63-amg-w...-2010-c63.html
Old May 5, 2011 | 10:44 AM
mbcoolguy's Avatar
c300
thanks matt you have been very helpful. so 245 all around with 10mm spacers all around on h&r supersport? seems as if everybody is running staggard on 18s. which would be better for rear? 245 40 or 245 35? thanks
Old May 5, 2011 | 11:01 AM
mbcoolguy's Avatar
c300
ok i think i got it. 18x8.5 et55 all 10mm front 5mm back 245-40-18 all with h&r super sport. so that equals to et45 front et50 rear. sounds good? btw thank you matt.
Old May 5, 2011 | 11:12 AM
w204 C300
BAM!!! Post pics in the offset thread when you get them with full specs!!!
