Old Jun 16, 2015, 07:50 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Lighting Guides
Print Wikipost
w204 headlight bulb(d1s) replace
Old May 9, 2011 | 04:00 AM
ks4life's Avatar
w204
hey guys,
i just ordered a set of 6000k d1s but i got no idea how to replace them. im attaching a pic of headlight unit from inside.
does anyone know how to release the light bulb?
Old May 9, 2011 | 04:39 AM
snarlingchicken's Avatar
2009 C350
Take the two clips you see there and push them down and inwards together. That'll release the bulb. From there you jsut unplug the connector and pull.
Old May 9, 2011 | 05:04 AM
ks4life's Avatar
w204
which part?
to snarling, do you mean the A part? or B part?
thanks,
Old Feb 21, 2022 | 07:48 AM
Dwags37's Avatar
2010 C300 4 matic
2015 c350 coupe w/ILS
I want to change the bulb in my ILS I want a different color than the yellow. Here’s the back of my headlight looks like there’s screws holding it in place and there’s no screw driver that could fit in there unless I tear the light apart. Seems crazy.
ILS headlights c204 2015
Screw to the left appears to be holding bulb in place. How do I remove these screws. (Inside the housing)
Old Feb 22, 2022 | 11:11 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Not hard at all.
No screws.
https://m.youtube.com/watch?v=3lshVPa_wh8
Old Feb 23, 2022 | 08:28 AM
JettaRed's Avatar
Veteran: Army
Is 6000K stock? I thought most cars use 4300K. The higher the temp the bluer the light. It might look cool in the parking lot, but not driving down a dark road at night.
This is one of the better depictions of light effects at different temps.
Old Feb 14, 2025 | 01:08 AM
Peachygarden's Avatar
03 c240 Mercades benz
03"c240 rewire drivers side headlight,main light housing
I own a 03' c240 4matic on the drivers side the wiring plastic melted and was a mess,now I have to hotwire my headlight to the battery just to have a little light. Has any one else have this same probably and had a solution would be helpful
Old Feb 14, 2025 | 03:56 PM
TimC300's Avatar
If you are talking about the wiring that is inside the headlight housing itself i have seen two options. One is to replace the headlight housing. The other option is to replace the burnt wiring, take apart the housing and basically make a new harness in there then close the light back up.
I would replace the headlight housing.
