whats the best cost/performance air filter and where can i get it?
Old Jun 1, 2011 | 01:15 AM
jpdaballa's Avatar
W204 C
so i'm looking for more throtlle response, and a little louder growl from my car,
any suggestions
a couple of friends have suggested k&m drop ins
Old Jun 1, 2011 | 01:42 AM
jctevere's Avatar
2012 C250 Coupe
K&N is really the only choice. Although, I doubt throttle response would be noticeably improved. You would benefit more from resetting the TCU (transmission control unit). If the throttle response still isn't to your liking you could purchase and install a Sprint Booster (relatively easy) and this will virtually eliminate your delay.
I haven't done K&N to my car as I have hard some people's MAF getting screwey from the oil needed (I hear its uncommon, and only happens from over lubricating with oil, but I don't wanna chance it as I would probably put on way too much).
If you want a better sound, I, and MANY forum members have installed x-pipes to the exhaust system. Hands down best mod for improving the sound of the car, and relatively cheap too.
Old Jun 1, 2011 | 01:51 AM
jpdaballa's Avatar
W204 C
i have magnaflow mufflers with xpipe already just looking for a little more..
that over lubing it is worrying me though is there a thread on this somewhere?
Old Jun 1, 2011 | 01:58 AM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
any suggestions
You will get a different roar sound out of your exhaust but it will not get louder, you also gain some extra horse power and a little deferent engine sound.
Originally Posted by jctevere
I have heard some people's MAF getting screwey from the oil needed (I hear its uncommon, and only happens from over lubricating with oil, but I don't wanna chance it as I would probably put on way too much).
That statement is true the problem is over lubrication
Old Jun 1, 2011 | 02:00 AM
jctevere's Avatar
2012 C250 Coupe
I recall seeing one or two people post saying they had an issue crop up with K&N filter on their w204 with the MAF throwing codes. I can't find those specific threads anymore, but if you do a simple google search on it, you can see other people talking about the same issue I was.
http://www.benzworld.org/forums/w204...placement.html
At the above link someone else mentions this "oiling" issue, and recommends K&N equivalent air filters that don't need to be oiled.
Old Jun 1, 2011 | 02:01 AM
jpdaballa's Avatar
W204 C
i want it to be deeper your sound clip sounds different then my car, in high revs i hear so much xpipe its not even funny
i don't know if thats because you have the 350 and i have the 300
Old Jun 1, 2011 | 02:07 AM
jctevere's Avatar
2012 C250 Coupe
http://www.youtube.com/watch?v=V_CqWhMh8oY
Try out that video. I made that one of my car (c300 4matic) and all I have had done to it is just the magnaflow x-pipe with stainless steel piping to extend the entire span to replace the resonator.
Old Jun 1, 2011 | 02:08 AM
jpdaballa's Avatar
W204 C
so i've basically heard all the bad,
anyone want to come in and tell me the good if there is any good?
if not i'm convinced not to get these
Old Jun 1, 2011 | 02:09 AM
jpdaballa's Avatar
W204 C
sounds really nice
Old Jun 1, 2011 | 02:14 AM
jctevere's Avatar
2012 C250 Coupe
Pretty much besides for the "negligible" power increase, if there even is one - jury can still be out on that. And the change in front-end growl (I haven't heard one in person to confirm this). The definite benefit is that you no longer need to replace your air-filters. The OEM ones are paper and aren't reusable, so every 30,000 miles (I believe that is the interval) you have to buy new ones.
Where as K&N or other aftermarket filters on the other hand are re-usable, so since they are about the same price (maybe a bit more than OEM) after 2 filter changes they start to pay off.
Personally, if you were going to go with the upgrade, I would get the ones mentioned that don't need oil lubrication. You can't go wrong there.
Thanks for the compliment on the exhaust.
Old Jun 1, 2011 | 09:32 AM
Richie999's Avatar
2011_C350
alternate perspective
http://www.knfilters.com/MAF/massair.htm
