Spring pads in the rear..
Old Jun 14, 2011 | 06:17 PM
dudeitsmattx's Avatar
2013 C250 Sport
Do you need the spring pads on the rear springs?
Old Jun 14, 2011 | 06:52 PM
Norm01's Avatar
2011 E550 Coupe
Yes
Old Jun 15, 2011 | 01:31 AM
2013 C250 Sport
Why
Old Jun 15, 2011 | 02:41 AM
Blazeitup123's Avatar
W205 c400 sport
By the way they are shaped, i believe they are to more evenly distribute the load of the spring over a lager surface area. They are round shaped like the spring on the one side and flat on the other.
I could be wrong as well.
Old Jun 15, 2011 | 10:59 AM
2013 C250 Sport
Ok.. I was not sure because there is non in the front.
Old Jun 15, 2011 | 11:37 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Our MacPherson struts have integral rubber insulators (pads) on their lower perches and the bearings’ seats.
They serve to locate the spring on the strut and eliminate metal-to-metal contact. No height adjustment capability though.
Old Jun 15, 2011 | 06:26 PM
2013 C250 Sport
I see. So where do they sell those 5mm spring pads people on here talk about to lower the rear just a little more since I already have super sports
Old Jun 15, 2011 | 07:09 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
You can get them from the dealer. I have a brand new set if interested. They're only $10 at the dealer though. PN A210 325 0184
Old Jun 15, 2011 | 10:40 PM
splinter's Avatar
Super Moderator
MB fits one of four different thickness pads during production, contingent upon options’ weight and intended ride height.
They’re readily identifiable in situ by the nubs or **** molded into their perimeter.
210 325 01 84 = 5mm/#1
210 325 02 84 = 9mm/#2
210 325 03 84 = 13mm/#3
210 325 04 84 = 17mm/#4
Note there’s also very thin shim/insulator/pad (204 324 01 84) installed at the bottom of the springs where they seat in their arms.
I've also used 'em topside to tweak ride height and adjust corner weights.
Old Jun 21, 2016 | 03:02 PM
fenesse4834's Avatar
2008 Mercedes Benz C300
yes I need pads
