Transmission not shifting as nicely?
It seems that in my 2009 the transmission doesn't shift as nicely or smoothly as the 2011 does. Especially when under load, almost as if there is a hesitation before upshifting. Whereas the 2011 does this instantly and I barely even feel the shift, if not for the sound change in rpm.
I was wondering if possible some values have gone, or are going bad in my transmission, or is this just the nature of the beast when you get a 2009 with 32k miles on the clock?
Also, I noticed that my key is becoming increasingly difficult to get out of the ignition when I turn off my car. It lets me turn the engine off and click once, but it doesn't let me have that second click that frees the key, I have to jiggle around turn back to accessory mode and off a bunch of times while moving the steering wheel and depressing the brake pedal. Perhaps I am starting to get a faulty ignition switch like so many others on here have been experiencing?
That would definately explain the differences in the shift feel.
oops
