DIY: Backup camera for 25$ (with pictures)
If anyone is interested, I will sell them shipped for $21.00 each. They are complete in thier original packaging. Each comes with Camera, Long Video Cable and power cable.
Let me know.
As my pdf attachment says, I used fuse 71 power, I remember it's for front accessory socket.
if you can help me, where did you install the fuse (location) and would you think thats the reason why that its causing that?
Hope I answered your question.
this might sound like a stupid question but how did you connect it? did you just connect the wire into the socket or is there like a wire the is connected to 71 that you spliced?
I removed some wire insilation (or called sleeve?) so that I could solder. Then used electrical tape to wrap around the solder joint. If you don't not solder, you can expose bare wire more and twist the camera wire onto the fuse wire tightly then tape it. I don't recommed that as reliability is not good. I always soder.
Any further questions are welcome.
hey bro thanks for the information i got the camera to work... GREAT HELP!
Good cameras are really worth it folks, for this and many many reasons reviewed elsewhere. I fail to see why one would by a Mercedes Benz and be very happy to put a Yugo (remember those?) quality camera in it.
I can always replace it with a good one. Thing is my cheap camera has 48 dB S/N. I don't see other cameras with S/N specs. Normally more expensive cameras should have better specs but I still want to see those numbers.
165° Wide Viewing Angle
Forward and Reverse Image possible
0.2 Lux Night Visibility
5 ~ 13Volts DC @ 80mA
380TVL High Resolution
70db S/N Ratio
Glass Lens
Waterproof
All Electronics in Camera
