w204 2011 change DRL's to LED?
the 2011 IS a LED unit, there are 7 (i think) LED lights next to eachother, you are thinking they are regular bulbs. All the LED strips are the same way, look closely on ebay or wherever. Theres no type of straight strip
i have the 2011 with the strip already, not the fogs, and am trying to change the bulbs because my illuminates more amber than white.
You could rewire the LEDs to an accessory connection and have them on full brightness at all times. just need to do the capacitor trick if you change from the pre-wired connection.
go for some more neutral colors closer to pure white and your LEDs will match... try 4500k for you HID bulbs and 5K AZN leds in the brows/sides...
soblem prolved.
Find a lighting/optics vendor who can provide a 7-light LED strip in 6k (your HIDs temp). Michael at AZN Optics on MBWorld may be able to help or there is always eBay.
Then if you want all lights to match I'd swap your 8k side markers LEDs for 6k (~$25).
This would likely be the cheapest solution.
same here dadangman placed an order with AZN for some 5000k, to replace my 8000k in my eyebrows, should be here soon...should look much better, then add in the SPYDER headlights and its a done deal.......
im thinkin of keepin my 8000k HID headlights but we'll see how the 5000k look with the DRL's, some contrast between the lows and DRL's/eyebrows might look nice...are you getting the SPYDER headlights
