COMAND Map Update Made Things Worse
Old Sep 27, 2011 | 11:39 PM
joshg1001's Avatar
2017 E300
I did the map update for the COMAND. At about 40%, it gave me a message that said that the update could not be further completed and that I should refer to the owner's manual. It ejected the disc. I put it back in and it continued
Well now that it is done, everything seems a lot slower to respond. For instance, it keeps telling me to "please wait" whenever I click on anything in the destination menu. It goes on forever and doesnt actually get me anywhere. I remember doing this update last year and didnt notice this happening. I am wondering if it will just work itself out or if I should reinsert the CD and redo the update (if that is even possible)
Old Sep 27, 2011 | 11:43 PM
2nice4me's Avatar
2011 E350 4 Matic
I have never done a command update but I would try and reinstall. I don't think it would do any more damage. good luck
Old Sep 28, 2011 | 12:27 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
What year Map Update is it?
What year Map Update is it? were you doing the 2011 or 2012 Command update?
Old Sep 28, 2011 | 12:47 PM
joshg1001's Avatar
2017 E300
I believe it is the 2012 or the newest one that is currently available
Old Sep 28, 2011 | 04:17 PM
joshg1001's Avatar
2017 E300
Tried to redo the install but it wouldn't take. It says that i already have the version on the car and ejects the disc
Old Sep 28, 2011 | 04:47 PM
IGB's Avatar
IGB
'08 C300 MM Pano
Is this an "original" disc or it is.... uhm... after-market?
Old Sep 28, 2011 | 04:59 PM
joshg1001's Avatar
2017 E300
It is the original disc
Old Sep 28, 2011 | 09:01 PM
joshg1001's Avatar
2017 E300
well I even did a system reset and was willing to lose all my contacts and saved radio stations. It did not do the trick. navigation is kaput
Old Sep 28, 2011 | 10:07 PM
ncglock's Avatar
E63
Did the previous user from the group buy report any issues?
Old Sep 28, 2011 | 10:46 PM
joshg1001's Avatar
2017 E300
its getting worse. Keypad buttons 7, 8, 9, 0 dont work on the radio screen. I did the system reset that changed the map display to default, pointing up and I cant change it to any other view such as birds eye. Voice command to set a destination does not work and says the function is currently not available. Doing it by hand does not work either and just gives me the please wait screen. Also it is showing the vehicle location a bit off than where it should be
I even did the reset on the secret menu.
Old Sep 29, 2011 | 09:46 PM
Ben'sBenz's Avatar
2009 C300 Luxury P1 w/Multimedia, Arctic White
It almost sounds like maybe some data on the hard drive became corrupt during the update. Or its getting ready to fail and all the writes during the update process pushed it near the end? Is your car still under warranty? I would take it to the dealer if so. I didn't have any problems when I ran the update. Let me know if you need the disc again and I'll ship it back to you when I get it.
Old Sep 29, 2011 | 11:28 PM
joshg1001's Avatar
2017 E300
Thanks Ben. I need a service A in October so yes, I might need the disc again so that they don't question the disc I used. In fact when the last guy gets it, it might just be easier for him to ship it to me and then I will return the disc to you.
