2009 C300 Wont start...battery fine...but no power to ignition
Old Nov 30, 2011 | 04:22 PM
zelliott's Avatar
2001 Mercedes Benz E320
When I tried to start my car it acts just like the battery is dead. I checked the battery with a gauge and it seems to be perfect. The car will not go in gear either (tried to roll it). The remote works and everything lites up but still no response. When I got out and hit the remote to lock it up the windows and sunroof opened and now I cannot get them closed. I thought it might be something to do with the anti theft alarm system and it had the car disabled in some way....any ideas ?
Old Nov 30, 2011 | 04:38 PM
CanadianSteel's Avatar
2006 C230 6 speed
Wrong forum mate. Your looking for the C-Class (W204) forum.
Not sure what the trouble is, but if anyone wants to take a stab at it.......
Old Nov 30, 2011 | 08:19 PM
Kaewen's Avatar
GLC250 Coupe
aint this the W204 forum?
your battery might be flat, since you cannot roll up the windows. There was some residual left, enough for you to unlock and open the windows... (just a thought)
did the starter crank or anything when you turn the key?
Old Nov 30, 2011 | 09:22 PM
Royce118's Avatar
15 E200CGI SPORT
Sounds more like the steering ignition module failing to me. A few members here have the same problem.
Old Dec 1, 2011 | 02:27 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
i would still try to boost it, even though u might think its not the battery
Old Dec 1, 2011 | 06:24 AM
Glyn M Ruck's Avatar
Super Moderator
I moved this thread to the W204 forum.
Does it not attemp to crank? If no crank check the starter solenoid fuse in the front SAM. On a W203 it is fuse 52 - check on your fuse chart for W204. If Benz has a 15amp fuse in there & it's blown change it to 20 amp. Recent TSB came out on W203 to this effect. The cars have much in common & many interchangeable parts.
Old Dec 1, 2011 | 09:53 AM
Kaewen's Avatar
GLC250 Coupe
ops sorry. my bad.
Old Dec 1, 2011 | 01:26 PM
Super Moderator
Not at all. I think in future we mods need to make this clear in the recipient forum. A "moved" notice is left behind in the donor forum.
I'm still settling into this moderator function.
Old Dec 9, 2011 | 07:40 AM
ICON 1's Avatar
2013 C300 Sport
I had the same problem a year ago. Battery and electronics all okay but engine would not start. Mine turn out to be an ignition kill module. It failed and killed my ignition. The repair took almost 1 month as each module is specifically programmed for each vehicle and had to come from Germany. You can unlock your transmission manually. There is directions in your manual but basically the plates around your gear shift simply pops up. Once removed you will see a yellow transmission manual unlock. It is either a simple press of it or a slide to one side. This will manually unlock your transmission so you can shift.
Old Jan 27, 2024 | 07:50 PM
Ewoodward's Avatar
C300
[QUOTE=ICON 1;4953539]I had the same problem a year ago. Battery and electronics all okay but engine would not start. Mine turn out to be an ignition kill module. It failed and killed my ignition. The repair took almost 1 month as each module is specifically programmed for each vehicle and had to come from Germany. You can unlock your transmission manually. There is directions in your manual but basically the plates around your gear shift simply pops up. Once removed you will see a yellow transmission manual unlock. It is either a simple press of it or a slide to one side. This will manually unlock your transmission so you can shift.
[Would your car try to start or would it not turn over when you turned the key?
QUOTE]
Old Jan 28, 2024 | 10:19 AM
ICON 1's Avatar
2013 C300 Sport
It wouldn’t start at all. No cranking. just completely dead.
