Tire Pressure Dilemma
However, are you SURE that it says 60 PSI? That's rather high - even for a spare. Does it say MAX PSI 60, or recommended?
If it states " maximum load xxxx lbs AT yyy psi ( cold)"then this is the pressure at wich the maximum load may be bare up to mostly 160km/99m/h.
This pressure is called the reference-pressure in the formula that the tire-makers use to determine the needed pressure for lower then maximum load on the tire.
If it states "maximum pressure 60 psi(cold), then it is the pressure where you may not go over when tires are cold ( so not driven with for a time).
But then even the this 1 psi would not be a problem for the spare.
But your tires are probably normal car tires or Extraload/reinforced/XL.
The difference then between reference- and maximum-pressure is used for higher speed and camber angle( alignment) of above 2 degrees.
Read about Toyo tires on a Westfield ( kittcar) with these maximum pressures, wich is higher then mostly, even for an XL.
But you can calculate the needed pressure with one of my spreadsheets.
In them I still use the European formula and its addings for speed and camber-angle, but am planning to rebuild them to my own formula.
You can read more about it on my public map on my skydrive , that belongs to my hotmail-adress with the same username as here.
I will give you the link to the map for recalculating for other then OEM tires, but can also be used to check the original.
My quess is that for an MB you can also go verry low in the pressures, like for the Westfield, but calculate it to be shure.
Then you can go lower for the spare too.
Could also be that the 61 psi was a miswriting in the manual.
https://skydrive.live.com/?cid=a526e...E092E6DC%21235
To use a spreadsheet, click on the line but not the name of it , then in the right barr the info apears, with also reactions, that you can give yourselfes also. There click on Download, and after download and eventual virus-check, you can open it in Excell or compatible programm ( Open-office-Calc fi) to use it. If you press wrong , it will be opened in the browser, but this cant handle some things , I used in the spreadsheets, so gives notice of that.
Then press "Skydrive at the top of page and go back and try again.
If you cant work it out, give me the details , and I will use it as an example here.
From this link you can navigate my complete public map, for more about calculating tire-pressure.
After this all you will see the stated pressures in its contence, and wont be bothered about this little difference.
Wayne
Wayne
Wayne
Wayne
