Transmission lag 2011 model
Old Dec 25, 2011 | 07:43 AM
nzkaveman's Avatar
2011 C200 CDI
Bought our first MB (C200 CDI) a few weeks ago (NZ), ride and quality is great, but both me and my misus definitely notice an "acceleration lag" from stand still. To the point you kind of feel when you pull into traffic it's like "woah hello you can go a bit more than this! the other cars are closing in!"
The perceived throttle response on our Corolla is much better(!) The transmission/throttle response is reasonable though once the MB gets going - 7G-tronics btw.
I don't feel this is turbo lag btw.. I've driven diesel vans and they pull away faster.
I will do more testing but I guess for now a few thoughts:
- do we just need to get used to putting the foot down more? (is this a MB "feature" of defaulting to comfort?)
- Has the TCU "learned" our slow daily commute?
- I will do more testing in S mode as well (manual says "vehicle pulling away in first gear", guess implies when not in "S" it's not?)
- Anyone with experience with lag in the 2011/12 facelifted model?
- Is there a way to check what version of firmware we've got / what version is latest?
- Are there differences in trannies between 2008 and 2011?
More info:
- 11th character is "A" so it's from the Sindelfingen factory in Germany.
Cheers
Old Dec 25, 2011 | 12:35 PM
qaz393's Avatar
AV6
i can step on the gas 1 second earlier to compensate when i am cornering, but are you talking about down shift or within the same gear??? my car respond almost instantly when above 3k rpm (V6 gasoline)
Old Dec 25, 2011 | 02:00 PM
Glyn M Ruck's Avatar
Super Moderator
This sounds normal. But to make sure your car is not defective ask the dealer to allow you to drive a demo to check if it is the same. Dealer can check software version with Star.
Old Dec 25, 2011 | 02:17 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
My 31 year old Peugeot 504 with 3 speed Borg Warner 35 ATM is more responsive than my 2008 220CDI at the lights or roundabouts.
Its a fact of life & we just have to compensate by forward thinking or buying a manual.
Old Dec 25, 2011 | 02:19 PM
qaz393's Avatar
AV6
if the transmission thinks its in the right gear for throttle position, the response is it. if it think it needs to downshift, have fun waiting.
Old Dec 25, 2011 | 02:43 PM
nzkaveman's Avatar
2011 C200 CDI
thanks guys for your response - very interesting how this is expected of MBs, I guess we will adjust driving style a bit!
should try in the demo car again you're right.
Old Dec 25, 2011 | 06:25 PM
Super Moderator
BTW - The worse thing you can do is mash the throttle to the floor. This will increase the delay. This is more so with petrol than diesel. On a petrol you have gearbox "decision" time or latency plus the ECU fighting to get the mixture under control.
Progressive acceleration will achieve the most brisk start.
Old Dec 26, 2011 | 12:53 PM
nzkaveman's Avatar
2011 C200 CDI
Did more driving with this in mind, it does actually feel it's a more to do with turbo lag (when starting from standstill); Didn't matter much if I was in Sport or Economy mode. Hah it does make me wonder how the car would drive with turbo "switched off" Anyone with info on power/torque curve between NA and turbo?
Once going kick down etc does happen quickly (wasn't an issue). So overall still pretty happy.
Old Dec 26, 2011 | 01:06 PM
acr2001's Avatar
2012 C300 4Matic
If this is the first Mercedes you've driven odds are that it is more of the wonderful Mercedes built-in lag "feature" than turbo lag, although I am sure that is contributing and making it worse. As already said, you just have to get used to pressing the throttle before you normally would. I have the facelifted 2012 and although the lag has been improved quite a bit, I still have the exact same problem you described - particularly when I am trying to quickly maneuver and then floor it in order to get out of the way fast. It can be infuriating. Last time it happened I was trying to make a very quick K-turn before traffic caught up with me, and as soon as I completed the K I floored it in order to get going ASAP as someone approached. Naturally the car laughed at me and gave me the full lag treatment.
Old Dec 27, 2011 | 07:41 PM
akmerc's Avatar
2012 C300 4Matic
Yep I'm a new owner of a 2012 C300 and I'm still getting used to the lag. I've had the car for about 3 weeks or so. I do not like it, but I love the car so I'm getting used to it.
It is surprising that something as intrusive as this is accepted AND that there isn't an aftermarket (or OEM) solution to counter it???
Or have I just been looking in the wrong places???
Old Dec 27, 2011 | 08:25 PM
xispaki's Avatar
Mercedes W204 C220 CDI
Hello Guys!
I have the same "lag" problem, and the dealer say that the problem was the exaust filter...He say also that from 500 in 500 km, the car injects more fuel to the cylider, in order to raise the exaust temperature to 600º, to renue something in the catalisor. well my car after 20 000 km whent to the shop to fix this problem (he dosen't pass from 3000 rpm), and they say that change the catalysor filter, and also the injectors.
The truth is the car after a wile have exactly the same simtoms..
I will take the car agian to the dealer, because it still have warranty for one more year. I forgot to tell that after this "lag" and when oyu stop the car there is an intense burn rubber smell coming from the left back wheel!
If you have any solution to this i appreciate...
Cheers from Portugal!
Old Dec 27, 2011 | 09:27 PM
acr2001's Avatar
2012 C300 4Matic
Originally Posted by xispaki
Hello Guys!
This problem probably should have its own thread as this is not likely the lag the other guys are talking about. It sounds like your parking brake or service brake is sticking on that wheel.
Old Dec 27, 2011 | 09:29 PM
acr2001's Avatar
2012 C300 4Matic
Originally Posted by akmerc
It is surprising that something as intrusive as this is accepted...
You got that right. Sometimes things like that boggle my mind. As far as a solution to the lag, none exists that I know of. The best possible solution would be to get the ECU reprogrammed (aftermarket), but I'm not sure about that either.
Old Dec 27, 2011 | 09:59 PM
Carsy's Avatar
Hello Guys!
It could be the smell is coming from the exhaust ? . The Particulate Filter may be in regeneration mode & burning off the carbon. ?
Interested to know the outcome.
Old Dec 28, 2011 | 06:55 AM
xispaki's Avatar
yes...that's what they told me, but the truth is, that every time that the "smell" appears the Lag also comes along!
I have a friend that works on Bosch car service, that told me it can be a way to solve this, by software, but for now and due to warranty issues, i will take it to the dealer!
Cheers!
Old Dec 28, 2011 | 02:52 PM
Carsy's Avatar
Cheers!
The lag may be normal when the DPF regenerates as the injection timing may not be at the optimum for driveability.
The dealer's mechanics should be able to enlighten you on all this. I look forward hearing also.
Old Dec 28, 2011 | 03:22 PM
akmerc's Avatar
2012 C300 4Matic
I'll do a search too, but since this thread is on lag, has anyone reprogrammed their ECU?
Old Dec 28, 2011 | 09:11 PM
acr2001's Avatar
2012 C300 4Matic
That would have to be done by a tuning shop. There are a few somewhat popular ones. No solid info about if they reduce lag. Usually they just advance timing inducing engine knock without higher octane fuel. A waste of time in my opinion.
Old Dec 28, 2011 | 09:47 PM
akmerc's Avatar
2012 C300 4Matic
That's no good for me. AK has 90 as the highest already!!
Old Dec 29, 2011 | 09:56 AM
kevink2's Avatar
2004 Mazda6, 1993 RX7
The Sprint Booster may help in this case, if possible borrow one. It opens the throttle more, for a given pedal depression. Many non-turbo people like it. I have seen no datalog that shows a delay in injector duty cycle or excees timingg retard, vs pedal depression, thus no hard evidence of "ecu lag".
If your turbo has "plain floating bushing" type bearings (vs ball bearings), make sure you use an approved 5W-30 oil, vs an XW-40 ... much less turbo lag. This is based on me running 5W50 vs 10W30 with sub-freezing temperatures (in my old SaabT).
I had an old Saab 900 Turbo (non-diesel), with terrible lag due to a ton of retard kicking in at about 3 psi ... like throwing an anchor out. I know this is not an option now for you, but I added an MSD Boost Retard module that replaced the boat anchor oem mechanical timing system for boost correction. That with the right oil turned the 4 cyl turbo into a 3L BMW strait 6, no turbo lag.
My Saab 900T, RIP
Old Dec 29, 2011 | 11:56 AM
akmerc's Avatar
2012 C300 4Matic
I've been thinking about the SB, and reading all posts about them.
I don't have anyone to borrow one from. What gets me is the people that buy them and then either sell, give or return them.
I guess it's be nice to know out of the 100s of people that have bought what percentage have been happy, indifferent, or dissatisfied. I'll search for a poll....
Old Dec 29, 2011 | 12:09 PM
kevink2's Avatar
My observation is most keep them, but those are not tubo diesel applications. Even if you don't like it, you are only out about $100 max as you can resell it.
Old Dec 29, 2011 | 12:16 PM
akmerc's Avatar
2012 C300 4Matic
Not sure if you think I've got a diesel or not. But I'm running the 3L V6 naturally aspirated engine....
Old Dec 29, 2011 | 01:08 PM
lm24's Avatar
C300
As others like qaz have mentioned before, this may just be the built in lag Mercedes decided to do. I believe our cars are drive-by-wire and the lag is programmed into the TCU. It is just something to get used to.
With that being said, have you tried using the tiptronic or whatever it's called to downshift in such situations (pulling the shifter left)?
Old Dec 29, 2011 | 01:44 PM
akmerc's Avatar
2012 C300 4Matic
Nah, I just give it some more gas!
To me the lag is a double edged sword. Like others have mentioned it does make the car very nice and smooth when taking off from a stop which I really like. But it also makes the car feel sluggish when you want to downshift and accelerate while driving.....
