Gentle Warning - Service your 722.9 Transmission every 39K miles 60K Km's
Old Oct 4, 2013 | 02:45 PM
  #126
macsp's Avatar
2018 GLC300 4Matic- White
Originally Posted by dave2001auto
See 722.6 tranny picture at:
http://www.benzworld.org/forums/w210...ssion-faq.html
post #6
The TC should look the same.
Thanks. I am trying to understand the overall location of the TC drain screw once the car is lifted. It looks like a single screw that uses allen key.
Old Oct 8, 2013 | 12:58 AM
  #127
dave2001auto's Avatar
84 300d 2009 e320 bluetec (retired)/, now 2012 E350 4-matic blueefficiency automatic
Yes, there is only one on the TC. It's wheel-like, so needs to be rotated until the drain plug is at 6 o'clock position. Lots of people use a large screw driver or pry bar to rotate the TC clockwise (front to rear view).
MBZ sell the TC plug with seal for about $4. The plug comes pre-treated with a lock tight material. There are two common sizes that MBZ uses. The part department can give the right size with the VIN.
Old Oct 8, 2013 | 09:47 PM
  #128
Uncle's Avatar
2010 C300
I serviced the transmission on my 2010 C300 2wd this weekend. Thanks to the forum it went very well. A few things that I can add:
1) The crankshaft nut is 27mm, and it allows you to easily rotate the engine to get to the TC drain plug. Engine turns clockwise as you face it.
2) There is a catalytic converter bracket beneath the transmission that does block access to the drain plug. It is easily removed with six bolts, and once off, the fluid will drain from the TC without dribbling.
3) I made a fill adapter using a 12x1.5 drain plug from O'reilly's. Drilled a hole thru it, and used JB Weld to attach a barbed nipple. Cost about $6.00.
4) Used a drill powered Jabsco pump to fill the transmission. I use this pump on my sailboats to drain the engine oil.
5) Judged the temperature by feel. It worked well, and the spill over worked fine.
All the other stuff is in the other emails, so I won't bother with those details.
Old Oct 9, 2013 | 10:00 AM
  #129
macsp's Avatar
Alright....took the car to the same dealer and they lifted up. Before taking me in, they realized there is TC drain screw!!! I went in and confirmed it. Now the dealer is offering to do the entire drain for FREE. They charged me less amount for the transmission drain because it didn't include the TC. Normally the complete drain is about $500 here. The fact is that they are correcting their mistake, but I need more from them to make me happy
Had I not read this thread/discussion forum, I would be just screwed up as many!
Thanks folks...great and helpful forum for people like me with no background in the vehicle repair/components.
Old Oct 9, 2013 | 03:42 PM
  #130
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Just shows that persistence pays. Congrats.
Says little for the expertise of the dealership.
Old Oct 9, 2013 | 03:52 PM
  #131
tmsiegle's Avatar
2010 C350 4M
That's great news! Must be a relief
Now I just need to wait and see if the folks here in Calgary give me the same runaround.
Old Oct 9, 2013 | 03:55 PM
  #132
macsp's Avatar
Yep, I sent a strong email to the Service department saying they lost my trust!!!
Old Oct 9, 2013 | 03:57 PM
  #133
macsp's Avatar
Indeed it is a big relief...just got a call back the dealer saying the car is ready for pickup and they used 9.5L of fluid this time.
They also confirm that the transmission fluid has to be changed only ONCE in the lifetime of the car. I assume this is true...or do I have to do more reading on that claim as well?
Old Oct 9, 2013 | 04:21 PM
  #134
tmsiegle's Avatar
2010 C350 4M
Seems to me that this is supposed to be done every 60,000 km...at least you have lots of time now to figure that out
Old Oct 9, 2013 | 05:28 PM
  #135
Carsy's Avatar
That's how I read it too.
Old Oct 10, 2013 | 01:26 PM
  #136
Pete7874's Avatar
'08 C300 4Matic Sport, '02 530i
Depends on how you define 'lifetime'.
Old Oct 13, 2013 | 10:14 AM
  #137
dennisfaul's Avatar
2005 C 320 CDI
No TC drain plug ion 722.9 box
Hi Guys,
I'm pretty sure I have one of the 722.9 gearboxes without the TC drain plug. I recently serviced the my box but could not find the drain plug. My question is how to I now go about replacing all the fluid including the TC fluid if I don't have a TC drain plug.
Any help on this problem will be greatly appreciated.
Old Oct 14, 2013 | 12:49 AM
  #138
Originally Posted by dennisfaul
Hi Guys,
c320 cdi ? Are you in the UK? I couldn't find a small diesel but would like one in the US.
Check to see if mbz sell the TC plug for your car using the VIN. See Wiki for a copy of the "flushing or pumping" out the atf
https://mbworld.org/wiki/images/f/f1...nflush2-1-.pdf
The 722.9 will use a similar method, except no dipstick tube and the use of a weir tube to adjust the atf level. See AP27.00-P-2702W for the filling procedure.
2009 e320 bluetec
Old Oct 31, 2013 | 12:07 AM
  #139
mmike's Avatar
'10 C300
are we sure that the TC has a plug on all W204 722.9 transmission? i talked to an indy and the dealer and both assure me that my vehicle w204 does not have a tc plug
Old Oct 31, 2013 | 07:53 AM
  #140
Glyn M Ruck's Avatar
Super Moderator
A 2010 should have a drain plug. From approx August 2010 build onward they are 722.9 Plus transmissions with 120,000Km drain & the new Blue 236.15 fluid.
Most dealers appear too lazy to remove the plastic plug in the bellhousing, rotate the engine until the TC plug lines up with the hole & remove it.
It should never be necessary to do the 722.6 flush procedure on a 722.9. That is for post 1999 722.6 transmissions that had their TC drain plug removed by some cost saving bean counter.
With 722.9 only a very few early transmission had no drain plug mainly fitted to S Class. Even late 7 speed W203's had a drain plug.
Old Oct 31, 2013 | 09:35 AM
  #141
Uncle's Avatar
2010 C300
My 2010 C300, 2wd, has a TC drain plug. I did the service three weeks ago.
Old Oct 31, 2013 | 09:49 AM
  #142
Super Moderator
There you go. As it should be!
Old Oct 31, 2013 | 03:37 PM
  #143
Carsy's Avatar
Hello Glyn,
Interested to know the latest thinking on whether to flush my 5 speed .(no drain plug).
The dealers mechanic who I trust said to just drain it & I think in the past you have said the same as long as the fluid is clean & not burnt.
At the 50,000 km drain the fluid was clean .
All this 'religious fervour' of complete draining of the 7 speed , is making me twitchy !!.
Thank you.
Young John.
Old Oct 31, 2013 | 07:05 PM
  #144
Super Moderator
JC ~ The 7 speed stresses it's fluid charge considerably more than the 5 speed. All those extra gear changes, clutch slips & lock ups. The fluid never looks great out of a 7 speed.
Old Oct 31, 2013 | 11:44 PM
  #145
Carsy's Avatar
Thank you Glyn.
Makes me wonder about the oppositions 8 speed!
The old ZF 4 speed always just needed a regular drain too & went on uncomplaining for ever.
Old Nov 1, 2013 | 07:09 AM
  #146
Super Moderator
Benz is developing a 9 speed as we speak.
Old Nov 1, 2013 | 11:45 PM
  #147
mmike's Avatar
'10 C300
Glyn-- Is there any documentation that I can bring in to prove to them that there is a TC drain plug?
Old Nov 2, 2013 | 02:16 AM
  #148
Carsy's Avatar
There has to be a balance between a gearbox for ever changing & smoothness, economy etc.?
Why not develop the DAF cones & belt system ?
Old Nov 2, 2013 | 08:02 AM
  #149
spyked's Avatar
2026 GLC300 4Matic (X254)
In the U.S., the 722.9 Plus only started for 2012 model year. C250 and C350 only. C300 got it in 2013.
Still looking for fluid CAPACITY (different for RWD and 4MATIC) and drain instructions on "Plus" transmissions and TCs with the new thin fluid and long drain intervals.
Old Nov 2, 2013 | 09:03 AM
  #150
Super Moderator
There is WIS documentation on the Johnand DIY service thread & the "I serviced my transmission but ---" thread & in the Wiki
A number of manufacturers have developed CVT's but there are efficiency & other issues & customers don't like the driving experience.
Thanks for the US intro dates. The plants must have been working off stock of the previous transmission.
