What actually changes when you go from "E" to "S"?
Old Jan 16, 2012 | 05:21 AM
BauerR's Avatar
'11 C300 Sport 4Matic, 911 Turbo, Fiat Abarth, Ram CTD
Not really seeing a difference.
Old Jan 16, 2012 | 06:01 AM
nicko36's Avatar
2007 C320 CDI 3.0l V6 Turbo Diesel
I think you are talking about "C" & "S" modes. C mode means comfort and the gearbox will take off in second gear for a more gentle take off, and it will not down shift to first gear.
Old Jan 16, 2012 | 07:25 AM
hyperion667's Avatar
2012 CLS63
e starts in 2nd, s starts in 1rst
Old Jan 16, 2012 | 09:00 AM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Shift points are also changed in S mode it tends to shift later but that mostly depends upon your previous driving habits.
Old Jan 16, 2012 | 10:50 AM
MBRedux's Avatar
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Physically I believe nothing changes, the programming for tranny's ECU does.
Old Jan 16, 2012 | 11:25 AM
Glyn M Ruck's Avatar
Super Moderator
All Boxes with S & C pull away in 1st in S mode & 2nd in C or comfort mode (old winter mode on early 722 series 5 speeds)
From the 722.9 technical training manual:
S (Sport) first gear start
C (Comfort) or E (Economy) second gear start, earlier upshifts and later down shifts. Auto default to E on Blue Efficiency models.
Note: Transmission will start in first gear if any of the following apply.
1st gear manually selected.
3/4 to full throttle applied from stationery start.
Engine cold (catalytic converter warm up)
Now - to precis the following: Certain high torque diesel models will pull away in first gear in both modes to protect the torque converter.
Old Jan 16, 2012 | 07:49 PM
r042wal's Avatar
2010 C350 Sport 4M
C mode uses the 7th gear on the hwy (gears 2-7) and S mode stays in 6 on the hwy (gears 1-6) making it sportier but harder on gas.
Old Jan 16, 2012 | 07:57 PM
akmerc's Avatar
2012 C300 4Matic
This is interesting. I wonder at what speed in E, it would shift up to 7th gear?
Old Jan 16, 2012 | 08:08 PM
Stevedotmil's Avatar
W204 2010 C300 Sport/6M
A lot I imagine. Anyone heading to Mexico to try out the speedo?
Old Jan 16, 2012 | 08:28 PM
victort's Avatar
2010 C300
any changes in the spring settings? ride seems harsher in S than on C on the same stretch of roads to me
Old Jan 16, 2012 | 08:34 PM
Boris0126's Avatar
2009 C-300 Sport
I have a quick question this is off topic but do the H&R Sport Springs of an 09 c300 4matic sport fit the 2012 c300 4matic sport? Thanks
Old Jan 17, 2012 | 12:27 AM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
No.
Old Jan 17, 2012 | 12:54 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Not true. Why does this keep coming up, I wonder?
Old Jan 17, 2012 | 12:56 AM
RLE's Avatar
RLE
Don't forget the higher ratio reverse gear in C/E.
Old Jan 17, 2012 | 05:18 AM
BauerR's Avatar
I know for a fact mine hits 7th in S on the highway.
Old Jan 17, 2012 | 07:31 AM
Super Moderator
Absolutely correct - 2 X reverse ratios - higher in C or E
The transmission goes all the way up to 7th in both modes i.e. in S & C or E
Old Jan 17, 2012 | 09:38 AM
LaicepsYdobon's Avatar
2011 E350 Sport 4Matic - P2 & Drivers Assist / 2010 C300 Sport 4Matic - P2 / 2013 Porsche Cayenne S
Not only that but I get better gas mileage in S mode then in E on both of my cars on the highway. The reason for that is there is less engine braking in S mode then in E which causes the car to have more "free roll" (for lack of a scientific term).
As mentioned before S will start the car in first gear (both forward and reverse) while in E the car will start in 2nd gear (forward and reverse). S tends to hold gears at a higher RPM while E tends to shift at lower RPMs to take fuel economy into consideration. Also in S mode the tranny is more willing to shift down for more power and quicker acceleration while in E it is less willing to shift down a gear. Unfortunately E or S mode has no effect on suspension stiffness since the C class doesn't come with the AIRmatic suspention.
Old Jan 17, 2012 | 11:05 AM
Super Moderator
The C does not have to come with AIRMatic suspension. It has to come with Advanced Agility Control where by pushing the separate "SPORT" button - not on the transmission control - The dampers firm up.
Old Jan 17, 2012 | 12:06 PM
I did not know that. That's pretty cool; thanks
Old Jan 17, 2012 | 01:05 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Cool
I disagree. There is no change in engine RPMs at 70mph when switching between S & C. Actually, I don't recall an RPM change at slower speeds either. 722.9 transmission in 2012 GLK 350 4 matic. YMMV.
I see above that this has been sufficiently debunked. One more internet myth down the drain.
Wayne
Old Jan 17, 2012 | 02:50 PM
acr2001's Avatar
2012 C300 4Matic
Yes, just like it does in E! (C for the pre-facelift folks)
