Lowering Springs Help....
Old Feb 24, 2012 | 10:40 AM
deaner1979's Avatar
2015 CLA45, 2008 C300 4matic, 2011 ML350, 2001 SLK32 AMG, 2012 E550
Hi,
having problems with suppliers up here telling me that there is no lowering springs made to suit a 2008 c300 4matic, i thought there was no diff...
any help or part numbers would help,
thanks
Dean
PS, also running 19's
Old Feb 24, 2012 | 11:11 AM
Invain15's Avatar
4matic C300
How low are you looking to go?
Old Feb 24, 2012 | 11:17 AM
jimmythegreek's Avatar
'11 C350 '13 F150 lariat
it is the same. how low you wanna go and whats the specs and tires of the 19s on ur car now
Old Feb 24, 2012 | 11:43 AM
deaner1979's Avatar
vossen vvs-083 - black/ machined
19x8.5, et 45 - 235/35/19
19x10, et 58 - 265/30/19
looking to be low, H & R supersports, but fine with the regulars if possible
Old Feb 24, 2012 | 04:34 PM
dude slam that thing with supersports, you will clear by a mile. actually you prob need 5mm spacers to clear the back w that high offset in back, esp in 10" wide. Its gonna rub the inside im almost positive, you will be the first to rub inside instead of outside LOL. I would do a 275/30/19 it will look even. otherwise do 225 in front so the stretch is more the same if you go 265, its gonna be stretched in back and almost straight up front the way u posted 235/265
Old Feb 24, 2012 | 09:40 PM
deaner1979's Avatar
the supersports for non-4matic fit 4matic?
Old Feb 29, 2012 | 12:48 AM
Boris0126's Avatar
2009 C-300 Sport
What are the consequences later or problems the 4matics will have for installing the super sports and not the regular sports? Cause i wanted to go with the super sports but i ended up going with the regular sports cause I didn't want any problems
Old Feb 29, 2012 | 02:21 AM
popp's Avatar
'09 C350 4M, '11 Sienna SE, '84 VW Jetta GLi
Supersports will NOT work on 4matics. Sports will
Old Feb 29, 2012 | 02:55 AM
itsLoonie's Avatar
2012 E350 RWD
Not necessarily. A member here did some research and apparently the springs are the same. He ended up getting the super sports for 4MATIC and they work fine.
His post is #128 in this link below.
https://mbworld.org/forums/c-class-w...port-ss-6.html
