Why is the C350 not much less efficient than C250 and way better than C300??
HPFPs are failing on the DI motors with BMW and Porsche (Bosch is the vendor.) I'm sure Daimler has done a lot of testing given the widely known problems with BMW, but some of the speculation has been that failures are connected to the fuel found in the USA. Mercedes diesels have used high pressure fuel systems for a long time but the fuel is totally different. Who knows yet if there will be issues with these new motors.
3.07 C250
3.07 C300
2.82 C350 -> 9% taller
I recall the transmission ratios were all the same for the 7 speed atx.
The Sales pitch:
7G-TRONIC PLUS 7-speed automatic transmission
The new consumption/efficiency-optimised 7G-TRONIC PLUS automatic transmission includes a DIRECT SELECT lever on the steering column as standard (except the CLS 63 AMG). The seven forward gears of 7G-TRONIC PLUS allow for a larger ratio spread between lowest and highest gears and still ensure smaller intervals from gear to gear. This guarantees optimum engine speed at all times, lower fuel consumption and virtually imperceptible gearshifts.
For quick bursts of speed, multiple downshifting allows the 7G-TRONIC PLUS to skip gears when changing down.
See pdf - The real deal
New 236.15 transmission fluid imminent - In fact already required. I will post Sticky with pdf.
