still drone after I dynamated my spare tire trunk
Is rubberized spray going to work if I spray it under my car to cover up the thin sheet of metal??
If I were to put back the stock resonator, I would have to redo all the piping again because I welded a magnaflow muffler (dual/dual) at this place where the resonator is..and muffler guy already redo the piping to the tips to make my maganaflow fit. so it will cost to much to put the stock back on...
'11 C350 '13 F150 lariat
I did aftermarket resonators w my meistershafts and it wasnt too bad of an install. I had already custom piped it and wasnt a huge pain to install them, and theres no drone at all and sounds badass. I did dynamat under the car along the midpiping and up under the spare tire compartment
ohhh...so dynamat won't melt under the car?? I was thinking about this for a long time
well... that might be my next move lol....
does that get rid of the drone??
Super Moderator
+1 - All you need to do is move the critical primary or it's harmonic, or sympathetic harmonic with another source out of the audible range. I did not realise this was a modified exhaust as Sportstick points out. I would try moving a metal weight up & down the pipe with a screw clamp & see where the resonance is least objectionable & then weld it there. Or change the resonator.
Mercedes Benz
My advice would be to put mufflers on. By taking off your mufflers, not only are you getting that annoying drone, but your losing back pressure. Which in turn,means lost power... Not worth it for sound. Either way, why would you want to attract all that attention? Save the non-sense for high school kids. You drive a Benz, not a crackerjack toy.
#33
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
Damplifier Pro and Dynamat are good products for what they were meant for...that being vibration reduction. They are not sound barriers however. They assist in preventing noise caused from panels/parts vibrating and resonating where they're attached, but if the vibration is coming from an external component that isn't wrapped, then Dynamat and Damplifier won't do much to help. You'll now need to put in a dense sound barrier (like the Luxury Liner Pro link I provided) to block the sound that you couldn't prevent from happening. The OP solution of putting in insulation will help keep heat/ac in the cabin, but won't help block external noise.
#34
SPONSOR/MBworld Guru
I used velcro to hold it down in place and foil tape along the edges. There's no need for it to stick fully to the panel as it's a noise barrier and not a vibration reducer.
#35
So even with the THICK luxury liner pro down there in the spare tire well, you were still able to fit the spare tire back in its place?
#36
I don't have the donut in the trunk anymore. Useless for me as the spare won't clear my BBK lol.
#37
so basically, there is no way to retain the spare tire anymore once you use the luxury liner in the trunk? Or maybe cut up the luxury liner into pieces.... but that might defeat the point....
I think those that retained the spare tire, just had the damplifier pro in and no luxury liner?
#38
I am glad you are happy, truly I am! But, I had to chuckle at the thought of anyone ever looking in the spare tire well and critiquing the color! That would just never be on my radar!
