iPhone integration w/ iOS 5
Old Mar 1, 2012 | 08:18 PM
mw4's Avatar
mw4
2012 C300
Just bought a 2012 C300 and tried to use the iPhone integration. It pulled down the phone contacts, the phone works fine, and the audio works via Bluetooth (Pandora, etc), but not the iPod tunes. I attached both a regular iPod, and an older iPhone running iOS 4.2.1. Both worked fine with the MB audio system. Any known issues with iOS 5?
Thx
Old Mar 1, 2012 | 08:43 PM
itsLoonie's Avatar
2012 E350 RWD
I play music from my iPhone playlist all the time with no problems and I have the updated iOS 5 on it.
Old Mar 1, 2012 | 10:32 PM
PilotAlan's Avatar
2014 CLS550 4Matic; 2010 E550, 2007 SL550
Thx
IPhone 4 w/iOS 5. i haven't streamed audio, but I've plugged it in and run playlists and such off it without issues.
Old Mar 2, 2012 | 05:59 AM
mw4's Avatar
mw4
2012 C300
Thanks for the posts, but I was hoping someone else is battling the same gremlin... I'll try it again today. Just found it odd that the music from a straight iPod and a 3G iPhone would work, but not a iPhone 4.
Old Mar 2, 2012 | 07:13 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
my ios5 iphone four wont auto reconnect! pisses me off....
I have to manually turn off and turn on my phone evertime I get in my car to get it to be recognized again...
anybody else have this problem ever???... pretty sure its my phone, cus it does the same thing with my wireless bluetooth stereo headphones now too...
Old Mar 2, 2012 | 09:42 PM
tasho3's Avatar
2014 C63 Sedan
My iPhone 4S won't download the contacts on my car, is there a trick for thus?
Old Mar 3, 2012 | 12:00 AM
PilotAlan's Avatar
Try deleting the pair and re-pairing, I seem to remember when you pair for the first time, there's an option whether to automatically reconnect.
Also, one of my bluetooth headsets had that problem, I deleted it and reconnected, and everything was fine.
Old Mar 3, 2012 | 12:01 AM
PilotAlan's Avatar
Same here. No answers for that one.
Old Mar 4, 2012 | 03:42 PM
mw4's Avatar
mw4
2012 C300
Mine pulled in the contacts, no problem, from my iPhone 4. It's playing the music from the phone's iTunes that has me stuck.
Old Mar 4, 2012 | 03:58 PM
Petje's Avatar
W205 C400
Go to settings on you iPhone , BT settings, MB audio and then you can select to sync your contacts.
Old Mar 4, 2012 | 07:55 PM
tasho3's Avatar
2014 C63 Sedan
Will try it, thank you
Old Mar 10, 2012 | 05:42 PM
PilotAlan's Avatar
It doesn't give me that option, only option is to delete the pairing.
For the people who have downloaded contacts, do you have COMAND, or Audio 20? I have A20.
Has anyone with Audio 20 managed to make the contacts download?
Old Mar 10, 2012 | 06:30 PM
tasho3's Avatar
2014 C63 Sedan
It doesn't give me the option neither
Old Mar 10, 2012 | 06:51 PM
Dirtywater's Avatar
'12 C350 Sport Sedan
I have the Comand S32 and I am able to load my contacts and stream music from my iPhone 4 w/iOS5.
After pairing my iPhone 4 (which gave me issues pairing until I deleted all other parings on the iPhone 4), it synched the contacts right away and later I went to bluetooth to play music off it and it said it wasn't connected, I selected reconnect last device and it worked.
Not sure if this helps.
Old Mar 11, 2012 | 01:09 AM
joshg1001's Avatar
2017 E300
ever since I got ios5, my phone wont charge in my 2009 ipod cable
Old Mar 11, 2012 | 09:48 AM
Petje's Avatar
W205 C400
Facelift W204 + Audio20 + IPhone 4
Contacts are always downloaded.
Dont know with the 4S but think it gas to work the same.
Old Mar 11, 2012 | 09:42 PM
PilotAlan's Avatar
That's exactly my setup, but no dice
Did it ask you? Does it do it automatically? Did you have to click anything?
