HELP please, my popup navigation display went black (open/close option is working OK)
Old Mar 18, 2012 | 02:01 PM
Martin_S72's Avatar
C300 Sport, C300 Coupe
I have 2008 c300 with Harman Kardon sound system and my display went BLACK. Radio and CD works fine and I can use cluster display option.
Did somebody deal with problem like this here before?
Is my display DONE.
Please help.
Old Mar 19, 2012 | 01:23 PM
Martin_S72's Avatar
bump
Old Mar 19, 2012 | 02:25 PM
mir_m's Avatar
c220
Must likely the LCD shorted
Had the same prob new command monitor
Required
Common fault
Old Mar 21, 2012 | 12:09 PM
Martin_S72's Avatar
Thanks man.
Old Aug 16, 2012 | 04:26 PM
Joker z's Avatar
2008 c300
Nav display
I am having a similar problem on my c300 that you had. The nav display is out. The rest is working. Were you able to figure somthing out.
Old Aug 18, 2012 | 08:38 PM
mir_m's Avatar
c220
In my situation it was the LCD screen that went in the motorised unit, I found it was cheaper to buy a second hand unit off eBay then change the LCD screen itself
Old Aug 18, 2012 | 09:37 PM
Nuru's Avatar
S350 BT 4MATIC
Agree that the Monitor is done. A number of the early ones for 2008 and 2009 had a dismal failure record, and were replaced by newer versions that were more reliable.
Old Dec 10, 2012 | 06:05 PM
Armymsgretired's Avatar
2008 C350
I have the same problem with my wife's C350. Display goes up and it will close. However, the display is blink. All other controls work fine. The navigation radio and all other systems work. Any help would be great.
Old Dec 10, 2012 | 06:36 PM
mir_m's Avatar
c220
It's mostly likely the monitor is gone
You if have access to star it can confirm your doubts
Merc can perform a screen test
If all controls are working it would lead me to believe it is the monitor
Easy to replace can be found on eBay
Plug and play
Old Dec 10, 2012 | 09:32 PM
2008 C350
Required
Common fault
Did you replace it yourself? If so where did you get it? What was the cost?
Old Oct 25, 2013 | 02:21 PM
olemissrbl5's Avatar
2008 C350
I would like to know what happened with this? Mine is doing the same thing! Why isn't this a recall? It seems to be a very common problem with this model.
Old Jun 2, 2014 | 03:35 PM
bucky408's Avatar
C63 AMG
Does anyone know the model number to the screen?
Old Nov 17, 2014 | 09:55 AM
2008 C350
LCD Display
Another thing I want to add here is when the screen pops up it flickers for 10 seconds then goes black. If you shine a flashlight on the screen then you can see it. I figured this out when I had to change the clock. Any one have the same result?
Old Dec 20, 2014 | 11:30 AM
chkrug's Avatar
08 C300
Command Center screen
My screen started flashing and every time I open the command center smoke comes out of the top left corner. Will this screen catch on fire?
Based on other posts, this seems to be a consistent problem. What are Mercedes and LG (screen manufacturer) doing about this problem?
Old Dec 21, 2014 | 10:28 PM
2008 C350
They should recall and replace this product! It's a fire hazard waiting to happen!
Old Dec 24, 2014 | 01:50 PM
calkong's Avatar
c300
I had the same problem, so I took it to the dealership and had it replace for free due to I had it cover under warranty.
Old May 7, 2015 | 11:48 PM
BarterLOL's Avatar
2008 Mercedes benz C300 Sport
Unhappy Help I have the same problem but....
I bought the screen online and it didnt work Too so then i decided to buy the cable that connects between the unit that pops out and the command it was 60 dollars at the dealer ship and it also didn't get fixed I'm thinking on buying the command it's self but I'm scared it might not work too �� if any one has any idea please help
Old Sep 29, 2015 | 08:45 PM
MC85's Avatar
2009 C350
Im in the same boat. Damn u lcd screen
Old Oct 1, 2015 | 01:33 AM
Rubie's Avatar
C350. 2008
I have this same problem and I agree, there should be a recall.
Old Oct 1, 2015 | 01:34 AM
Rubie's Avatar
C350. 2008
Going in for service tomorrow and will get the model number and some answers.
Old Oct 14, 2015 | 10:45 PM
Modelimx's Avatar
MercedesC300
I'm having the same issue...everything works fine but the screen. Without warning or any issues up until this point, it just all of a sudden went black. I have purchased a new LCD screen and swapped it out, still no luck. I even took the old screen to an electronics dealer and had them test it. Turns out it's not the screen. I purchased a new iPod intergation wire from the MB dealer because someone mentioned it might be that, still no luck. It was also suggested that maybe it's as simple as a software update-something the dealer could do for $300. I don't know but I'm at a loss of ideas here. Any help would be much appreciated.
Old Dec 13, 2015 | 01:06 AM
ML350_2oo6's Avatar
ML350 2006
Having same problem. Let me share my research on his issue.
Hi everybody. I have an identical issue. Looks like I went a but further in my investigation so I'll share my experience.
At what point screen went blank:
I was trying to remove already synchronized phone from the unit, and the unit froze on the "deleting the phone" screen and I could hear the unit was making the "I'm busy" noise. It froze to the extent that it wouldn't react to any buttons, turn/off even car's on/off. Eventually it drained the battery so that I couldn't even turn the car on. I had a batter boaster so I was able to run the car. After which I've noticed the screen was blank. Since then (till now) screen is blank.
Now, about my investigative steps:
1) Removed the fuse for the unit (using fuse diagram, also made sure it's he right fuse by checking if the unit is completely dead) put fuse back, problem persists.
2) To rule out bad screen, I had my original cracked screen (which was turning on, just cracked screen) and this was blank too.
3) After putting back the good (non-cracked) screen i removed the unit and checked the fuse (there's one fuse on the unit itself, behind it) - fuse was fine. Re-checked all cables, looked fine. Screen still dead.
4) I've noticed that even after above steps the unit kept my radio channel shortcuts which tells me that there's an internal battery in the unit.
Does anyone know how to "factory reset" this unit?
Unit model: MCS
Unit model No.: BB0541
The car is ML350 2006.
The car has the optional Tooki Bluetooth connection.
p.s. I originally posted on another Benz forum, in case if you're interested to check what users say on there, here's the link http://www.benzworld.org/forums/audio-telematics-forum/2524089-command-screen-went-black-sound-functions.html#post13464089.
Old Dec 13, 2015 | 01:08 AM
ML350_2oo6's Avatar
ML350 2006
Any updates?
Any updates to share? Thank you!
Old Dec 13, 2015 | 10:09 AM
ML350_2oo6's Avatar
ML350 2006
Following up
Is there any news on this matter? Thank you!
Old Dec 13, 2015 | 10:11 AM
ML350_2oo6's Avatar
ML350 2006
Hi there. Following up.
Any news on this? Thank you!
