C250 starter cranking issue
As far as your described issue with the delay in starting/cranking the engine over, I experience the same issue. After sitting for a period of time (overnight), when I go to start the engine there's a delay of about a half a second to a second after turning the key and the engine cranking over. This has always been the case with our '08 300, so I just assumed this was normal. I don't have a specific answer for you right now, but wanted to let you know that you're not alone. Hopefully some of the other members can help shed some light on this. Aloha!
1-You say sometimes it cranks long(turns over longer than normal, before it starts. In this case I assume the starter swings correct speed, engine just take longer than normal to fire up.
Reply to this:My car C350 had this problem since new, they could never found this fault. It has done it some months ago. I just switch off, then it starts quickly.
They did replaced the crankshaft positioning sensor on 1st service, due to a bulliten about bad batch from factory. Now I started noticing this after this replacement, but they everytime assured me the CPS is ok.
2-You say further down, that someties the starter cranks slower....Now this is a different situation, I had to replace the battery after 8 years for this.
3-Delayed start, I assume it is meant if you turn the switch or push a button, you hear no starter turn for a while, then it turns-?
Im not sure which one you ment or both-?
finally it was known to be the cm shaft position.
changed them and that's end of story
I came across your thread regarding your C250 hard start issue, and was wondering how did things turn out for you? I basically have the same issue, but MB is fighting me on the ext warranty repair.
Thank you
