Swear I've searched; how do you set stations on HK?
Old May 27, 2012 | 12:40 PM
will_w204's Avatar
97 S600 coupe/gf 16 C300 Lux. Former: 08 GL450, 83 300D, 97 C230, 08 c300 luxury, 92 500SL, 93 400E
I can't find it in the manual either! This should be simple! I've had the car a year, and haven't figured it out. If i go to a station (FM) and hold the button down, it goes to the previous-owner's preset station instead of overwriting. What am I not doing?
Old May 27, 2012 | 03:12 PM
Domm's Avatar
'08 Mercedes C300
What button are you holding? It should be the dial numbers.
Old May 27, 2012 | 03:50 PM
alsyli's Avatar
2012 C250 Sport
I don't have the HK system, but I can't imagine that the way to pre-set stations would be different? You're pushing the number buttons on the keypad, yes? Are you holding it down long enough? You basically hold the button until you hear a beep, at which point the desired channel will have overwritten whatever was there before....
Old May 27, 2012 | 04:02 PM
will_w204's Avatar
Ha, I never paid attention to that keypad as I figured it was for phone-related functions. Ok, so I use the keypad, press a number til I hear a beep. Which menu am I in at this point? Give me the preceding steps, if any. I was going into the preset menu on the dash, selecting the station manually, and then holding the select button down, which is obviously wrong.
Also, a side question for those who have MM pack.......do playlists work with this setup? I'm trying to figure out how to mirror my ipod to the SD card
Old May 27, 2012 | 04:09 PM
acr2001's Avatar
2012 C300 4Matic
Why not just read the f'ing manual?
You won't be in any menu. From the radio screen you just tune to the channel you want. Hold button until it beeps. Channel is now assigned to that button.
Old May 27, 2012 | 04:17 PM
will_w204's Avatar
I really did rtfm, but apparently I couldn't find what I was looking for in the 1,000 plus pages of legalese. Thanks, I'll try to set them.
Old May 27, 2012 | 04:19 PM
acr2001's Avatar
2012 C300 4Matic
Admittedly, the manual is a pain in the butt.
You can use playlists with MM as I see the option in there, but I couldn't tell you the specifics as I haven't tried it.
Old May 27, 2012 | 04:29 PM
will_w204's Avatar
Thanks all
10 stations set. I now see what I was dooing wrong; it's easier to "feel" than explain. I was going into the dash audio menu, and holding the steering wheel select button down. It only works using the console controller, apparently. The dash number pad is irrelevant it seems, just swivel to the station you want and press down on controller, while you're in the preset menu, on the appropriate line.
Old May 27, 2012 | 10:27 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
It is very simple. You tune to a station and then hold down the number you want to preset it to. Almost every single car I've ever been in has the radio presets set to a numbered button...
I don't see how the dash number pad is irrelevant... it is far easier IMHO to select a preset (or set it) off the numpad rather than scrolling through the menus on the steering wheel or in-dash screen. The buttons are well within your peripheral vision and the five has a little bump on it in case you need more help finding the right button.
Glad you figured it out...
Old May 27, 2012 | 10:55 PM
acr2001's Avatar
2012 C300 4Matic
Yep, you're doing it wrong! The number pad is far more intuitive / easier to use for setting and retrieving stations. You need to be on the radio screen - where it shows the frequency / song titles. Then after you tune to your station you hold whichever number button you want to assign it to. Hold until a beep is heard. It is now assigned. Nothing will pop up on the screen.
Old May 28, 2012 | 12:13 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Just like every other car radio on the planet.
ONE YEAR??
Old May 28, 2012 | 01:24 AM
acr2001's Avatar
2012 C300 4Matic
ONE YEAR??
Huh?
Old May 28, 2012 | 03:38 PM
will_w204's Avatar
ONE YEAR??
Yeah, I've bothered to mess with it like 3 times in a year. I guess it isn't a big deal as I got used to scanning or listening to the ipod. I'm turning into my grandparents. I always used to laugh at how the stations were never set, and they didnt bother to figure out how their new Benzes and Caddys worked. lol
