Appreciate maintenance advice on leased C350
I have 35,000 miles and will turn the car in next Feb but will hit the 40,000 service well before that. This one is on me and I was dismayed to see auto trans service needed. I was more dismayed to see that it isn't a simple DIY affair (either is the oil change). The car is immaculate and has been well cared for and I am a believer in doing things correctly. That said I am not nuts about a 600 plus service a few months before I have to turn the car in. I was going to do everything myself but see that isn't an option. Then I figured I would change oil and skip tranny service (I have reset sequence thanks to the help of the board).
Any thoughts comments as to what you would do (or have done) would be helpful. My wife would probably only have 43,000-45,000 at turn in so maybe that falls into a grace period for sevice?
Anyway, love the car and beautifully engineered but the non user friendly maintenance aspect may keep me from another.
Thanks in advance.
And, yes, there is that pesky need to abide by the lease terms.
Thanks in advance.
As far as changing the oil, you said you were dismayed to learn it is not easy.
I honestly believe that this car is THE single easiest car in existence to change the oil on (ok, don't hold me to that)! You'll need a pump (they're not that expensive, last forever, and you can use on nearly any car).
1. Remove easily accessible filter housing.
2. Replace filter and o-rings. (don't reinstall filter housing yet)
3. Stick tube into dip-stick tube, suck out oil.
4. Pour new oil into the oil filter hole (it's like a built in funnel!)
5. Check oil level, reinstall filter housing.
6. Drink beer.
Regarding oil change simplicity, I was never a fan of the pump from the top school and figured a one time purchase of device didn't really make sense. That said the transmission change is the big issue obviously.
I have read post on this but still find it hard to believe that the trans fluid needs change at 40,000 miles and that you can't easily check levels without factory tool or extraordinary effort. So I guess 1) I am questioning the need (unless there is a design flaw) since no other modern vehicle I have come across has this requirement. So I don't feel as if I was hurting the next buyer (MB 'owns' the car now) as much as taking one up the ying yang. It not as if I was not changing oil for 20,000 miles or having bad repaired tires, etc. This is maintenance that I really question. I believe the 40,000 service also calls to replace brake fluid that was changed at 20,000? Wow.
The comment about maintenance required under lease is certainly true. I have not checked independent garages (I live in Chicago area) and this may be an option. That said when I turn the car back and there are no service lights on I think that is pretty much the end of the game. No other lease return (I have had dozens) makes any inquiries on maintenance.
Additionally my 'exceptional' care for the vehicle will certainly put dollars in the MB pocket.
I am afraid that my comments make me sound like a non caring, automotive hating 'cheapskate'. I enjoy cars, like to work on them,
and pride myself in doing the correct maintenance using the best parts.
MB might have just stretched my tolerance a bit on this service requirement and technique, particularly withinn the timing of my lease
Any other thoughts, or ideas are certainly welcome.
https://mbworld.org/forums/c-class-w...s-60k-kms.html
Regarding brake fluid, no matter what brand of car, it should be replaced every two years. Being a hygroscopic fluid, it absorbs moisture from the air, which deteriorates the fluid.
Also, I'm not sure at what intervals you changed your ATF in your previous cars, but a quick google search for "common" cars like the Toyota Camry or Honda Accord will show intervals recommended at 40k-50k across several model years and the more careful owners are changing at even lesser miles (30K). So I'm kind of surprised you find 40K hard to believe.
Brake fluid is covered above.
I second RLE's comment on previously leased vehicles.
Whatever your decision OP, good luck! I'm glad that "non user friendly maintenance" is your/your wife's only complaint!
Let us know what you pick for her next.
In the last decade I have leased the C350 Sport, 3 cadillac CTS (one V) 2 -3 series BMW's, a Mazda Millenia (it handed down a few times with 10 plus years service 150,000 miles zero breakdowns (and no tranny flush). All were maintained to at least the level of the manufacturers recs (the Mazda was given to my son after five years) It does seem as if some maintenance intervals are guided partially by the function of profitability. BMW who offer 'free' oild changes carry there intervals out to an extreme. I cite an internet comment below on the BMW:
BMW’s Free Scheduled Maintenance program means that BMW will perform scheduled maintenance free of charge during the BMW New Vehicle Limited Warranty period.
Prior to the advent of BMW Free Scheduled Maintenance, approximate BMW maintenance recommendations were: automatic transmission fluid (ATF) and filter changes every 15,000 miles, manual gearbox and differential oil changes every 30,000 miles, annual brake fluid changes, and coolant changes every two years. Spark plugs, air filter, and fuel filters were typically replaced every 30,000 miles on most BMWs (this is a tune-up) except M cars up to 1995, which got new spark plugs and a valve adjustment every 15,000. Later advances in computer engine management and spark plug technology legitimately allow 60,000-mile spark plug life if not more.
Prior to Free Scheduled Maintenance, you couldn’t change engine oil often enough according to most dealerships. And when the car was in the shop it would often be due for this service or that inspection, all at the owner’s expense.
But once BMW began paying for scheduled maintenance, lo and behold the “schedule” was revised. Now the cars hardly need any maintenance at all. The 1,200-mile break-in service was done away with except for M cars. Engine oil suddenly lasts 15,000 miles (dealers are supposed to use BMW synthetic oil). Manual gearbox and differential oil? No worries there – now BMW says they NEVER need to be changed; it’s “lifetime fill.” Brake fluid and coolant service intervals were doubled with no change in the original BMW brake fluid and anti-freeze dealers are supposed to use.
So, is Free Scheduled Maintenance all about marketing and cost reduction – BMW’s costs? Draw your own conclusions. There is no doubt that many buyers correctly view BMWs as “high maintenance” cars. Nothing can address that more effectively than Free Scheduled Maintenance. But the operative word in the name is “scheduled.” In my opinion, extended service intervals and “lifetime fill” came very close on the heels of Free Scheduled Maintenance.
No disrepect to the MB faithful intended here in any of my comments as I always appreciated advice on these forums.
