Fix Fender to quarter panel and headlight to hood spacing after finder bender?
https://mbworld.org/forums/c-class-w...luck-ever.html
They repaired and repainted the fender but the headlamp is on order and will be in next week.
Well, the side part of the fender has about a 1/2 cm gap that's not present on the other side. (between the fender and quarter panel.) Then on the top side of the damaged headlamp there is a slightly larger / slightly more noticeable gap than normal between the headlamp and hood. Do any of you have any experience with these sort of repairs? On this car is it pretty simple as in just adjusting a bolt? Or is this sort of repair more complicated. They said that they would adjust the fender when the new lens is being installed next week? Is this over optimism? Am I going to have to replace the fender afterall or can these spacing issues be resolved pretty easily.
Thanks in advance,
John
Normal headlamp spacing -
Look at the spacing between the hood and the headlamp.
Normal front fender -
Abnormal fender spacing (between quarter panel and fender.)
Again its very minor, but if I look at it I can see the connector on the inside, and I am a bit of a perfectionist with my cars so I really want it to be right..
