Quad Exhaust 2012 C250 (JB+ Tune & Intake)
Old Feb 3, 2013 | 01:00 PM
100degrees's Avatar
C250 Cpe, E90 M3
Did you install heatshields to the right side?
Old Feb 12, 2013 | 08:53 PM
hotcorner216's Avatar
2008 C350 Benz, GLA250 4matic
Sexy tips
Old Feb 13, 2013 | 03:29 AM
aluo325's Avatar
2012 C250
Does your setup drone while idling?
Old Feb 13, 2013 | 03:57 AM
AllEyesOnMe's Avatar
C Coupe
I have same setup without the Magnaflow. Basically straight pipe. No drone at all. If anything, the exhaust is too quiet for an aftermarket. You will not even know you have an aftermarket exhaust when sitting idle.
Old Feb 13, 2013 | 04:10 AM
Project C's Avatar
MB C250
Can post some pictures pls?
looking for exhaust mod my 250 cgi but not too noisy.
stays low profile.
just quote from Kleemann downpipe with high flow cat.
still looking for extractor (header).
Old Feb 13, 2013 | 12:05 PM
C Coupe
stays low profile.
Here you go! Sorry i don't have clearer pics
Old Feb 13, 2013 | 12:18 PM
  #32
Project C's Avatar
MB C250
Wow, so nice! i was poison
Wasn't that sound loud if you drag?
Old Feb 13, 2013 | 12:42 PM
  #33
C Coupe
Definitely not. Like i said, if stock exhaust was 3/10 in terms of loudness (10 being C63 AMG loud), this one is maybe 4/10 under normal driving. More aggressive driving, it will be 6.5/10).
*No cabin drone AT ALL!!!
*I cannot imagine those who installed a muffler/resonator to this straight pipe setup... It will be TOO QUIET!
However.............. If you remove the primary and secondary cats, then this will be LOUD. So if you plan on doing that... leave some space in your straight pipe setup so you can add a muffler later... Just cut the pipe and insert new muffler and you will be set.
Old Feb 13, 2013 | 12:57 PM
  #34
Project C's Avatar
MB C250
If that's the case ill be most probably setup similar like yours , of cos without the muffler.
exactly what i'm looking for. can have some sport loudness when high rpm. but normal driving is comfort and wont disturb the neighbours mid night when i'm home.
i heard is better to add a power flap for those who did a Y pipe. it actually have dual sound from low to high rpm range. Most of it's purpose is to get better respond all the way
Old Feb 13, 2013 | 01:01 PM
  #35
Project C's Avatar
MB C250
The link:
Old Feb 13, 2013 | 03:14 PM
  #36
kevink2's Avatar
2004 Mazda6, 1993 RX7
Sorry for the quick topic change, but this is a late response on the exellent and inexpensive Burger box for creating a massive torque increase from 2600
Originally Posted by jctevere
.... And as far as the tune goes, gains are up to 20 hp to the wheels and 40 torque to the wheels from 2500 to 4500rpm according to the dyno burger tuning has performed. Peak HP hasn't really increased much..
The 20 hp increase occurs at 3800 and 3000 rpm, and the claim of "20 more hp" is misleading by Burger. In this case, the gain is just a by product of the fat torque increase at that rpm range, and no other tuner would try to suggest this as THE hp increase. That is the only verbal claim that I found to be false and misleading.
What everyone is interested in is the increase in "max-hp", which as you noted is small as in 6-7 hp. The interest by most is false, as they never drive above 4K rpm. But to the people that want to see a dyno curve, the increase in max-hp is important, as it directly affects the 1/4 mile times, and performance when shifting several gears at redline. Low end torque increase is felt by more people, as it falls in the normal rpm range, and may help 0-60 runs.
As far as my impressions, turbo lag is much improved, there is an awesome blow-off sound now. The car pulls much stronger from 2,000-4,000 rpm and it makes the ride much more "enjoyable". Definitely worth it - not to mention that the mod is relatively cheap at $280 and is very simple to install.
I'm with you 100%.
Now on the new Burger intake, I wonder if they have any data for improvement, like AIT readings, differential pressure, or dyno? Nothing on the website. Based on the Rx7 Twin Turbo upgrade evolution that I played a small part in, open intakes like this were best for track use, where the influence of heat soak did not exist. But for a daily driver, some shielding surrounding the filter, using the hood as the top shield, worked best.
Old Feb 13, 2013 | 04:28 PM
  #37
kevink2's Avatar
Racing, Hyundai GC 274 hp, vs C250 201 hp ?
Originally Posted by wnunez89
good stuff buddy!! im digging the exhaust. makes me miss my TI tips
Now that JB tunes are coming out for these cars Im gonna have to watch my back in the genny. I raced a 250c a few weeks back in my GC and lets just say it wasnt pretty for the 250 lol.
You have no reason to worry about the C250, it likely has a smaller turbo and
a bit more weight. 274 oem hp doesn' have to worry about 201 oem hp (208 with the box). They are not similar cars. Now put your directional on and move over to the right if you see another similar 2.0T car, if it's a stock Lancer EVO, OEM specs at 291 hp, 300 ft-lbs (about the WRC limits) .
Old Feb 14, 2013 | 02:02 AM
  #38
aluo325's Avatar
2012 C250
Do you happen to have any videos? I would love to hear your setup.
Old Apr 6, 2013 | 03:42 AM
  #39
kkd79's Avatar
213 C250 Coupe
What is the size of your piping and y pipe? Thank you
Old May 3, 2013 | 11:54 PM
  #40
C Coupe
I will try to make one soon. Please subscribe to this thread for that update.
It is 2.25" all around
Old May 22, 2013 | 03:33 PM
  #41
2012C250's Avatar
2012 Mercedes C250
so your magnaflow and y pipe are weldedd together?
Old Feb 10, 2014 | 06:49 PM
  #42
larry.spam's Avatar
2012 C250 Sport
I found the following cat-back quad exhaust online: http://www.ssaccessories.com/servlet...tFor-08/Detail
Has anyone heard of Becker Performance exhaust systems?
