Looking for Winter Tires... Recommendations?
I did a quick search and I wasn't able to find this.. I have a 2012 C-350 and I am wondering what would you guys recommend for winter tires? I live in Canada and the snow here is pretty thick.
Should I stick with 18"? 17" (which is the one I am leaning towards to)? Or go all the way down to 16"?
For the size you recommend what tire should I go with? (The thickness is the one I am after) I see different recommendations from different tire sites.
Thanks in advance.
I might give Nokian a try this round. My friend also recommended kxwheels .com for online orders because he had good experiences with them. Any more local/Canadian stores somebody can recommend?
I think 17" is what I am sticking with for this car because the 18's look kinda tight for snow.
Thank you guys for the input. I will check out more local shops.
That size is also wider than optimal for winter.
Thanks again for taking your time to answer this newbie question.
Personal experience. And my Nokian WRG2s aren't squirmy in the wet & on dry pavement like my former 16" Blizzaks.
Dealer said I need P225/45R17 but on tire size calculator, it said P215/45R17 and P215/50R17 are both within 1.5% of the speed difference. Am I safe with either of those 2 alternatives or do I have to stick with P225/45R17?
The dealer also told me that the TPMS is built into the speed sensing so I don't need another set of TPMS for my new set of wheels+tires. Can somebody else confirm this?
What dealer told me is contradicting with this post here made about a year ago: https://mbworld.org/forums/c-class-w...50-4matic.html
The dealer only knows and will recite OE specs. Don't worry about that. You can do other sizes which are within a close spec and fit your wheels, per the 1010tire calculator. I did not run the numbers, but would think the 215/50 was the closer fit.
Canadian cars don't use TPMS sensors, as I recall. They use wheel rotational speed to assess pressure variance through the ABS wheel speed sensor.
If any of you Calgary guys want a deal on ANY winters, i can hook you up.....
Give me a call and I'll give you some choices.
Igor.
For the record, I do agree that these are one of the best winter tires on the market, but not in that size - this is probably why you got a deal.
Igor.
