Oil change: MB dealer or Tire Kingdom?
called my dealer and he said it will cost $107. Is this a fair price?
--- also what does Complimentary multi-point inspection include?
Tires--use a higher-end specialty shop that can line a MB properly or use the dealer.
Oil--do it yourself with an extractor and the proper oil/filter or take it to the dealer or qualified Indy that you have researched and believe in.
I would not be surprised to see your MB up on the rack and some kid running around under the car looking for the filter.
Don't let a place like tire kingdom (jiffy lube, valvoline, cheeze dog empire) touch your car. I know its an oil change, but they'll put a paper filter in it (they only last 3 months) and you have a 50-50 chance of them either skipping the re-seal O-ring or asking if you know where the drain plug is. I am not kidding.
Dealer is too expensive and they always have kids doing the oil changes. Dealer may not be that bad if you ask them for just the oil change some said they got quotes of like $89. There is value to having the oil changes recorded in the VMI. Just not a $250 value.
Find a good indy and talk with them. you'll see why. Many of them are former MB master techs that got together and started their own company. That is what you want. Sure they'll hire kids too, but they will watch them and train them properly.
Of course you can always decline any additional repairs, but basically that is what it means: more business.
Sometimes they actually might find something significant, but usually they just try to upsell. To the tune of fuel injector cleaning for $xxx and so on.
DIY
https://mbworld.org/forums/c-class-w...-pictures.html
And this is the liqui vac I used it seemed to work pretty good
http://www.jpcycles.com/product/740-...FSOnPAod-V0A-A
Best way purchase the correct oil and filter from MB
Give them to the local shop shop and they charge you for labor
You then know what is going in your engine
http://bevo.mercedes-benz.com/bevolisten/229.5_en.html MB approved oils
At 40k there is a required tranny service - fluid change and I believe the air filters. Dealer price on the tranny service is rediculous but you really should do this while in warranty otherwise they'll charge you for any tranny work they need to do. Indy will charge like $150ish dealer like $400.
when it runs out however we will be looking for a merc independent or a quality reliable garage. It is after all a oil and filter change not a mercedes capable only item
That said I'm happy to use the fast oil change places on my 94 jeep but would not use them on the wifes merc
I know this will sound snobby and it's not something that's intended
when we bought the merc we did our homework, we knew it would need higher grade gas, longer trips to a decent workshop( sturgis to denver anyone
) , and a higher maintenance cost. had we thought we did not want to pay the higher cost of keeping it on the road then we wouldn't have bought it.So as to your oil change, if you can do it yourself then try it. next if you can't then look for a decent local garage or independent merc specialist and lastly a merc dealer
good luck
https://mbworld.org/forums/e-class-w...servicing.html
That $110 quote for an oil change, I would do that if I didn't get the $89 quote I referenced. just not $250-300 for svc A
MB has always said change it every two years.
