AMG Door PIN Install WOW!!!!
Old Feb 13, 2013 | 06:26 PM
livestrong191's Avatar
2008 C350
Went to the dealer today to get my signal lights on the side mirrors replace and a MB Campaign (wiring harness for camshaft adjustment & solenoid ). So I asked for a qoute about replacing the Sh#$%ty door pins in my current C350 with the AMG steel ones and was blown AWAY with the price (parts and labor) $226. See Pic Blow: Sorry for the bad quality pic
Old Feb 13, 2013 | 06:41 PM
snowmuch's Avatar
C63 AMG
Um, you can DIY takes like 10 mins
Old Feb 13, 2013 | 06:43 PM
2008 C350
Yeah I read some of the threads but people are removing door panels and such got me a little worried. I thought just unscrew and screw in a the new one
Old Feb 13, 2013 | 06:45 PM
snowmuch's Avatar
C63 AMG
The front is unscrew and screw. As for the rear doors if you don't want to remove door panels. Just put some super glue on it, that's what I did and works great. The reason why is because the amg door pin is tiny bit short for the rear.
Old Feb 13, 2013 | 06:48 PM
2008 C350
ok cool. So u put super glue on the inside of the rear amg pins to hold them right.
Old Feb 13, 2013 | 07:16 PM
snowmuch's Avatar
C63 AMG
Yup that's what I did
Old Feb 13, 2013 | 07:37 PM
Sportstick's Avatar
Another round of ICE
https://mbworld.org/forums/c-class-w...door-pins.html
Please see posts #4 and #12
Old Feb 13, 2013 | 11:16 PM
2008 C350
Originally Posted by Sportstick
Ok sweet I just ordered my door pins off ebay. Thanks for the help
Old Feb 16, 2013 | 02:33 PM
Savage c-300's Avatar
C300 Sport, MM, P1
It's not hard to take off the rear door panels. seriously only takes 10 minutes and removal of 1 screw on each side.
Old Feb 16, 2013 | 08:17 PM
MBSebas87's Avatar
C300 Sport 4Matic
I just used crazy glue for the back lol....any idea why the difference between front and back?? You would think they are the same lol
Old Feb 19, 2013 | 12:53 PM
2008 C350
So got my pins today. I just installed the front two that you need to screw in. I guess when i was at the dealership and asked for a quote for a door pins and install the tech must of looked if their pins fit because I barelly had to twist them to start unscrewing. I am scared to do the back rear ones. I will try this weekend. I got my pins on ebay.
http://www.ebay.com/itm/Mercedes-Ben...126820&vxp=mtr
Old Oct 2, 2013 | 09:44 PM
Sammaj's Avatar
2013 C250 Sport
I did a ton of reading trying to find a straight answer to wether or not the amg pins sit flush with the front doors. Finally i settled and bought this set of 4 pins for about 50 bucks!
They sit flush, a breeze to install and they dont have the amg logo. I put the on a 2013 c250 sport
http://www.ebay.com/itm/221213339759
Hope this helps!
The back pins are pull ofs on mine, snapped the new ones in.
Old Oct 2, 2013 | 10:44 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
i did all four from ebay as well...look great...did not remove door panels did not use super glue..been on car for about 8 months
Old Feb 28, 2014 | 12:01 AM
suminub's Avatar
C-250
Hope this helps!
i hv a 2013 C250 sport too. I am holding off ordering this, just coz I dont want to break anything while attaching the back pins. Can you confirm that the back pins were as easy to install as the front ones?
Old Feb 28, 2014 | 01:26 PM
xaran's Avatar
2012 C 250 Sport Sedan
2012 C 250 I installed these pins a few months ago. its a 5-10 min install. Front screw on and the rear pull off and then push on and snap on. I did not need to use glue they fit perfectly
Old Feb 28, 2014 | 07:06 PM
Carlos.33193's Avatar
C250 2012
I also used some glue for my rear and been fine for 6 months.
