LED H7 Fog Light Bulbs
Old Mar 13, 2013 | 11:35 PM
sharkey_lsu's Avatar
2013 C63 AMG
So I have purchased the Phillips Diamond Vision H7 55w fog-lights and they look great at night but I cannot get past the terrible blue bulb that is seen during the day when they are not in use.
My question is has anyone purchased LED H7 fog-lights and if so please make some recommendations. I came across these on ebay which is where I got the idea to use LED instead of standard halogen:
http://www.ebay.com/itm/300871574176...84.m1423.l2649
I know that I could do the HID retrofit but I do not have time at the moment for such an installation so that is not an option.
Old Mar 13, 2013 | 11:57 PM
glj12's Avatar
C300 Sport
LED is fine. It will do an /okay/ job with projection. The only caveat is that you will need a load resistor, which it may or may not come with.
Old Mar 14, 2013 | 01:22 AM
dansonchan's Avatar
2009 C300 Sport 4MATIC™ Sedan
load resistor cause heat and can burn everything
Old Mar 14, 2013 | 12:39 PM
deaner1979's Avatar
2015 CLA45, 2008 C300 4matic, 2011 ML350, 2001 SLK32 AMG, 2012 E550
whats a good kit for HID fogs (plug and play)?
Old Mar 14, 2013 | 05:28 PM
Duals1ns's Avatar
MY2010 6.3///AMG Markus Jaudes
Here's a link for LED fog light that have CAN-BUS that will not set a warning on your cluster. (Plug & Play)...
http://www.carid.com/2009-mercedes-c...s-3127009.html
Old Mar 14, 2013 | 09:31 PM
glj12's Avatar
C300 Sport
That's an H11 form factor; read: for C300 Luxury.
Old Mar 14, 2013 | 09:34 PM
glj12's Avatar
C300 Sport
No, that's not only wrong, but it does not make any sense.
To effectively disperse heat, yes it does need to be mounted to a piece of metal. If you do not mount it, will it "burn everything"? No. The resistor will get too hot, thus killing the bulb.
Luckily, there is a vertical bar within the fog assembly region where you can mount the load resistor. Note, if you have a sport, you need an H7 form factor bulb. The H7s (from what I have seen) do not come with built-in error-free CANBUS.
Good luck.
Old Mar 15, 2013 | 02:37 PM
Duals1ns's Avatar
Here's the H7 LED light bulb.
http://www.carid.com/universal-led-l...s-3659434.html
Old Mar 15, 2013 | 05:18 PM
glj12's Avatar
C300 Sport
That's awesome. I had such a hard time finding it since I was only looking on eBay. I'll have to add carid to my list then.
Thanks, Duals1ns!
Old Mar 15, 2013 | 05:24 PM
Duals1ns's Avatar
No problem.
Just make sure you order two, it doesn't come in a set/pair.
Old Mar 24, 2013 | 09:09 PM
aowhaus's Avatar
2008 C300 Sport 4matic
I'm curious to know the loss of brightness with the LEDs, as LEDs tend to be less bright as the beam is directional and doesn't utilize the reflector as effectively as a regular bulb.
I want to switch to LED bulbs, as the regular bulbs heats up too much and melts the protective film I have on the glass.
I am thinking of getting these LED bulbs in yellow and I have some extra resistors with an aluminum heat sink casing left over from another project which I could use to eliminate the error codes:
http://www.ebay.ca/itm/2pc-Yellow-H7...261fc2&vxp=mtr
Old Jul 3, 2014 | 04:02 PM
sedici's Avatar
w204 c350
Thanks, Duals1ns!
Did you ever change fog light bulbs to led? I was planning on purchasing the following only unsure how they would be with cornering lights.
http://www.carid.com/2008-mercedes-c...-25675245.html
Old Feb 26, 2015 | 06:50 PM
iMakeLuv2myMB's Avatar
c300 sport
i just bought these for my 2009 c300, and they flash like 3 or 4 times then i get the error. any thoughts?
Old Feb 27, 2015 | 02:06 PM
aabc's Avatar
GLK 350 NO LOGIC 7, NO KEYLESS GO
http://www.carid.com/articles/what-d...to-my-car.html
This is because LEDs are a low voltage circuit and use a lot less power than the original incandescent bulbs they are replacing. So low, in fact, that the vehicle will determine the LED bulbs are actually an open circuit (burnt out or missing bulb) and will cause an effect called “Hyper Flashing”, where the turn signals blink excessively fast. Other issues that may be caused from this low voltage include the Vehicle Information Center indicating you have a bulb malfunction and you may not be able to activate your cruise control anymore.
Old Feb 27, 2015 | 02:15 PM
c300 sport
will the load resistors fix this issue?
Old May 3, 2019 | 12:11 PM
Amaral0139's Avatar
C300 4matic sedan
GLJ12 did these work for you. I have bought so many and I keep getting an error message on my '12 mb c300 trying to find something for my cornering lights
