FS: Chrome Door Trim
Old Mar 24, 2013 | 11:59 AM
glj12's Avatar
C300 Sport
Cool FS: Chrome Door Trim
Hey all,
Does anyone need the bottom door chrome trim for their vehicle? Comes with all 6 pieces.
PM me if you are interested; name your price.
Old Mar 26, 2013 | 05:37 AM
xjaymzzx's Avatar
2002 slk 32 amg, 2013 c300 4matic sport
How did u remove it from your car?
Old Mar 26, 2013 | 08:33 AM
glj12's Avatar
C300 Sport
It was rather difficult and time-consuming, given the age of the vehicle. What resides between the aluminum and the door is a thick strip of tape.
To remove, you take fishing line (as dental floss will break too often; I would recommend at least 6-8lbs line) and place it behind one of the starting edges. Move your line to rest perpendicularly and make a sawing motion with your arms as you push through the glue. The line will probably break several times.
Once removed, you will have this wretched glue on your vehicle. Dig your nails underneath one of the corners, and peel it off as slowly as you can -- otherwise, it will piece off in centimeters.
Now, it will look like you have a ridiculous residue that almost looks like it is engraved into your vehicle. To remove this residue after the tape has been fully removed, use Meguiars Rubbing Compound and rub thoroughly.
And there you have it! I hope that this helps.
Old Mar 27, 2013 | 01:03 AM
MB_inspired's Avatar
2012 C350 4matic
If you use a heat gun, the piece will come off much cleaner. Hair dryers don't put out enough heat.
You can also remove the residue with a specific 3M product designed for adhesive removal. Essentially spray it on, let it soak (it's almost a foam like substance), and the stuff makes it much easier. Then you can use the rubbing compound after followed by a coat of wax for protection.
Old Mar 27, 2013 | 02:44 AM
funkedelic's Avatar
2010 c300/2008 335i
Pic of the trim removed? Thinking of doing this as well. Gl with sale
Old Mar 28, 2013 | 12:19 AM
glj12's Avatar
C300 Sport
FS: Chrome Door Trim-u1oils7.jpg
Old Mar 29, 2013 | 08:01 AM
xjaymzzx's Avatar
Thx for the help! Car looks awsome!
Old Mar 29, 2013 | 11:38 AM
glj12's Avatar
C300 Sport
Not a problem, and thanks!
Old Mar 29, 2013 | 01:20 PM
xjaymzzx's Avatar
Did you have a hard time changing out the grill? Also im doing the blackout tape for the window chrome. Its hard to do it without the bubbles!
Old Mar 29, 2013 | 02:16 PM
glj12's Avatar
C300 Sport
I bet the blackout tape is a difficult task -- good luck.
The grill was pretty simple. Lift up the hood, remove a couple of screws surrounding the plastic flap that partially locks down the grill, then lift it up and out at an angle (there should be a hook on the right holding the grill down. If you want something more specific, take a look around the forum and you should see DIY videos, pictures, etc.
Cheers!
