Power Steering Out
Old Jun 23, 2013 | 01:15 PM
W204Man's Avatar
08 C-Class (sold)
Power Steering Out
So a few days ago I hit a speed bum very hard (did not see it) and the power steering was making a weird noise. the dealer service adviser described it as to much fluid moving. He told me that the power steering filter must have been knocked lose so the fluid was bypasing the filter and making the noise. His solution was to replace a few parts, would cost a few 100$ and would be done by the end of the day. so I said ok. Parts on my bill sr 62 reservoir, power steering & oil tank & gasket & hydraulic oi ended up being about 300.00. Two days later they finished and it still made the nose. That really pissed me off and thin he said it was the Rack In Pinion and that cost like $5000?! I was about to go off on this guy. Second time had has been wrong about a problem on my car. So I just took the car home and will take it somewhere else on monday. I thought it would be ok to go to the dynamos game last night but that was a mistake. On the way into town my power steering stopped working for a second or two thin came back on but felt really weird. On they way home I was in stop and go traffic for like 40 min. Got off and took the hardy toll road and thin my power steering completely went out. The first noise went away and a new noise started. A whining noise that matches the engine rpms. So dose anyone have any idea what to replace?
please excuse any spelling or grammar errors
Old Jun 23, 2013 | 04:21 PM
Glyn M Ruck's Avatar
Super Moderator
It sounds as though the pump has failed & generating insufficient pressure. Your dealer SA sounds like a disaster.
Get someone that knows what they are doing to check it all properly. Its not a complex system.
Old Jun 24, 2013 | 11:14 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
If it is the expensive rack I'd file an insurance claim. That's what it is for.
And yes, your SA sounds like a typical MBUSA dealer SA.
Old Jul 7, 2013 | 12:04 PM
W204Man's Avatar
08 C-Class (sold)
It's the power steering pump. I have the pump but I also need the high pressure hose from the pump to the rack. But I cant find the part number? Can someone help me find the part number. And does anyone know how hard it is to install?
Old Jul 7, 2013 | 01:55 PM
Super Moderator
What model is it? Complete your profile.
Old Jul 7, 2013 | 04:45 PM
W204Man's Avatar
08 C-Class (sold)
2008 c300 RWD
Old Jul 8, 2013 | 06:06 AM
Super Moderator
Note different LHD, RHD requirement
250 A 204 460 55 24 EXPANSION HOSE
PUMP TO STEERING [005], [006]
001 L
250 A 204 460 03 24 DELIVERY LINE
PUMP TO STEERING
Replaced_By: A 204 460 58 24
+001 A 204 460 64 24 [007]
001 R
250 A 204 460 58 24 EXPANSION HOSE
PUMP TO STEERING [008]
001 R
30 A 015 997 22 45 .O-RING
DELIVERY LINE TO STEERING 001
50 N 000000 0000276 SCREW
HOSE TO STEERING
M8X20 001
120 A 015 997 22 45 .O-RING
LINE TO STEERING GEAR 001
130 A 006 997 61 90 HOSE CLAMP
HOSE TO COOLING PIPE
15.5 MM 001
140 A 000 990 16 17 SCREW
HOSE TO FRAME-TYPE INTEGRAL SUPPORT
M6X12 001
140 N 000000 0005956 SCREW
HOSE TO STEERING
M6X15 001 R
170 A 006 997 61 90 HOSE CLAMP
HOSE TO COOLER PIPE AND PUMP
15.5 MM 002
PUMP TO STEERING [003]
001 L
PUMP TO STEERING
+001 A 204 460 64 24 [004]
001 R
001 R
260 A 001 990 12 63 .HOLLOW SCREW
PRESSURE HOSE TO PUMP 001
270 N 007603 3016105 .SEALING RING
16X20-CU 002
280 A 015 997 22 45 .O-RING
290 N 000000 0000276 SCREW
HOSE TO STEERING
M8X20 001
310 A 221 466 02 40 HOLDER
PRESSURE LINE TO ALTERNATOR 001
320 N 910112 2006003 NUT
DELIVERY LINE TO BRACKET
M6 001
350 A 204 460 01 35 HOLDER
PRESSURE HOSE TO COMPRESSOR 001 R
360 N 910112 2006003 NUT
M6 001 R
390 A 204 460 62 24 EXPANSION HOSE
STEERING TO COOLING PIPE [003], [006]
001 L
390 A 204 460 69 24 PRESSURE HOSE
STEERING TO COOLING PIPE [007]
001 L
390 A 204 460 09 24 HOSE LINE
Replaced_By: A 204 460 64 24
+001 A 204 460 58 24 [004]
001 R
390 A 204 460 64 24 EXPANSION HOSE
STEERING TO COOLING PIPE [005]
001 R
400 A 015 997 22 45 .O-RING
410 A 006 997 61 90 HOSE CLAMP
15.5 MM 001
420 A 000 990 16 17 SCREW
M6X12 001
420 N 000000 0005956 SCREW
HOSE TO STEERING
M6X15 001 R
440 A 204 460 20 24 COOLING PIPE 001
460 A 204 466 12 81 PRESSURE HOSE
FROM COOLING PIPE TO PUMP 001
470 A 006 997 61 90 HOSE CLAMP
15.5 MM 002
Old Jul 8, 2013 | 10:43 AM
W204Man's Avatar
08 C-Class (sold)
my car is LHD.
Thanks so much for the parts list.
