Sport Mode and Shocks?
Anyone know what the magic button does with the suspension? I know it changes the shift characteristics very noticeably on the 7 spd automatic, which I like.
Does your button look like this?
If so, then yes it does. Or at least it's supposed to. I can definitely feel a difference between on and off with mine.
You can also open up your hood to see if an electrical connection to the top of each of the front shock absorbers exist.
Thanks for the under the hood tip. I'll check that out. It's amazing how tech these cars are.
The button in question is directly to the right of the driver side heated seat button. I believe anything located on the shift console may be exactly what everyone else is suggesting, in that it'll only affect your transmission shift points. For me, the button you describe only changes automatic to manual mode. In order for me to go to regular vs sport mode requires the button I'm referring to: which changes the shock dampening, steering effort, throttle response and transmission shift points.
I forget if you are the original owner. If you were, you would know because this is a 1.5k special order line item that generally doesn't come standard to the US market.
EDIT: Just ran across your first post and you stated you were the 2nd owner. In that case CONGRATS! If you do have the dynamic handling package as I mentioned, you are lucky, since that is not a feature that you would normally find in a Mercedes lot. Usually ANY special order requests (line items marked with "SPC") come directly from the factory ordered specifically for an intended buyer.
No, my C350 does not have it. Instead, in line with, and at the rear/end of the P N R D markers on the shift console (7-speed automatic) is a button marked "E-S". It toggles the driver between Economy and Sport modes. It definitely affects the shift points, and maybe the lag time when shifting. I'm referring not to manual shifting but leaving it in D, or automatic.
You can shift it manually by manipulating the shift lever left and right in either E or S modes.
However, when I engaged sport mode, I felt the shocks noticeably firmer...
Macolam, notice the + and - signs on either side of the D. That's how you shift this model manually, whether in E or S mode. I like it because you don't have to look down at it; it becomes second nature. The amount of resistance in the shift lever is just right.
I think it's mainly due to our own habits .
Once you turn on sports mode there is no "guessing"...you will clearly know when it is on.
Go Navy: Where in the Bay Area do you live?
A good test is to go on the 92 San Mateo Bridge (7 miles of straight road with expansion joints). With Sports mode OFF, you can cruise with the back of your head resting on the headrest. With Sports mode ON, you cannot as doing so is essentially asking for a headache.
AND/OR pop open your hood. Does the top of each strut tower look like this?
I may be wrong, but I believe part # (a005 542 1218) is the electrical connection for each unit.
Macolam: I actually prefer paddle shifters; had them on my '06 Acura RL, which got traded in as part of the purchase of the C350.
