Keeping it clean
Before any rust has appeared, take off the wheels, simply clean and paint your rotors with Zinc Galvanic spray, this makes the rotors look like the car just rolled off the production line and it is very durable,
I took these photos after my last car wash and I have rolled at least 5000 miles since I painted the rotors, I really love the brand new OE look.
Front
screen capture windows 7
And rear
image hosting flickr
I should have used what you used but I had some silver Rustoleum wheel paint which has held up pretty well for a couple years.
The Zinc Spray is an exact color and texture match to the OE rotors.
Looks like I may have to clean em up and try again.
http://jnci.oxfordjournals.org/content/95/13/1004.full
Most plumbing worldwide has at least some galvanized piping. There is no huge plan to eliminate zinc from plumbing soon (it's not like asbestos, which can cause serious health problems even with low exposures).
Like any commercial aerosol spray paint, a mask with goggles and gloves are recommended. It is NOT however "highly carcinogenic" and should not prevent one from taking vic_viper's great suggestion.
Zinc on the other hand is harmless enough to be used in thousands of facial creams and is a component for topical medicines that promote skin healing. Wherever you saw that zinc is "highly cancerous" must have been referring to a specific zinc compound, where the other components can be cancerous, not the zinc. Here is an example of zinc preparations for the skin, and cancer is NOT one of the side effects:
http://bodyandhealth.canada.com/drug..._id=5278&rot=4
In any case, the Rustoleum Cold Galvanized product, as with any spray paint, can be highly effective or abused. Hope everyone's rotors look like new soon.
(wrote this before I saw your post xXHotelCrazyXx, sorry)
Few questions, Which zinc compound do we use? Bright or Cold? differences in those?
How do you get all of rotor when the calipers & brake pads are in the way?
How long to wait before driving?
how many coats?
Should we worry about the thickness of the coat?
Thanks.
Paint 2 or 3 coats then it should be dry and driveable in 30mins.
Indy workshops wouldnt paint rotors prior to install unless you specifically ask and pay for it.
