Why not use the same size tires all around?
Old 08-04-2013, 09:21 PM
stratman1954's Avatar
2012 C300 sport
I have a 2012 C300 Sport. I like the car, especially the looks, but don't really care that the rear tires are bigger than the front. The only thing I don't like is it rides too harsh for me and the fact the tires don't last too long, partially because you can't rotate them. So why not put a set of Continentals on it all the same size and rotate them. Any opinions? And would you use the larger or smaller size tire all around?
Old 08-04-2013, 09:27 PM
2012 C300 sport
Just noticed OCDBenz has a similar post
Old 08-04-2013, 09:33 PM
Sportstick's Avatar
Another round of ICE
Same size tires all around are fine....and then you can rotate, just like on the Luxury model. Use the front size 225/45-17 for all four. It will fit up to an 8.5" rim, which is what you have in back. Staggered tires are not why the ride is harsh...that's the suspension calibration and the particular type of tire you now have. If you are trying to improve ride quality, look at tirerack.com surveys for Grand Touring All Season and consider any of the top 5...you will see their relative merits.
Old 08-05-2013, 12:26 AM
2006_C350's Avatar
2010 C300 & 2014 E350
Make sure you have 17X8 in the front and the rear. I don't think you want 17X8.5 in the front and 17X8 in the rear.
Old 08-05-2013, 01:03 AM
djejglk's Avatar
2013 C250 sport
That's what I was thinking. If you went with 4 of the same size tires and rotation time comes, you would have 8.5 in the front.
Old 08-05-2013, 02:20 AM
EuroJDMBenzo's Avatar
Mercedes benz c350 sport
i dont know why but i like having a staggered setup
Old 08-05-2013, 05:49 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
If you went to 55s the ride would improve. I rejected the car with 45s but found the 16" 55s acceptable. The ride & length of suspension travel is the only things that in my opinion are below par with this car. Owner aged 66 years old & travelling on broken country roads.
Old 08-05-2013, 05:50 AM
Carsy's Avatar
Think man think
Old 08-05-2013, 07:03 AM
Carlos.33193's Avatar
C250 2012
Your wheels are different widths. When you rotate your tires they're going to charge you to dismount and mount the tires on the wheels + balancing.
Old 08-05-2013, 10:32 AM
caligreenzzz's Avatar
W204
Me too.....otherwise looks a lil lame.....
JohnnyQuest007 (12-31-2021)
Old 08-05-2013, 10:40 AM
mb techman's Avatar
CLA45
Old 08-05-2013, 10:41 AM
mb techman's Avatar
CLA45
Old 08-05-2013, 11:21 AM
C250 2012
Originally Posted by mb techman
if you do this, and rotate, the 8.5" rim will hit the caliper and/or strut on the front.
Yep. You're easily looking at $100+ every time you want to rotate your tires.
Old 08-05-2013, 11:27 AM
Sportstick's Avatar
You are quite correct, and I should have been more clear that this allowed tire rotation, but not tire and wheel rotation.
If he was shopping for new rims, then same size rims of 7.5 or 8" width would work at all four corners.
Sorry for making an assumption......
Old 08-05-2013, 10:57 PM
2012 C300 sport
Never dawned on me the wheels were different widths. Thanks everyone for the help.
Old 08-06-2013, 01:21 PM
robnyc's Avatar
X4M, G80 M3
I use to have 235/50/R18 in my Cadillac all four, even though it came staggered with 255/ in the rear forgot if it was 35 or 40 ..
my bmw had 225/60/16 all four (AWD) but i left it stock
Does your C250 rides on 225/45-17 front 245/40-17 year like my C300 4Matic Sport i' just got ? 235/50 is just a great size overall would it fit our car ?
Old 04-19-2014, 09:56 PM
JOE W's Avatar
C300 4matic sport
Just picked my new toy up this past week,looks as if this site will be a big help.
Old 04-19-2015, 12:36 PM
Upstate88NY's Avatar
2009 C300 Sport 4Matic
Would this also works for a C300 Sport 4 matic? does being 4matic prevents from going all size or it wont matter? thank you
Old 04-19-2015, 08:27 PM
vendsit's Avatar
2009 C300
Staggered wheels
It doesn't matter. I have an 09 4Matic and went with aftermarket wheels and 235/40/18s all the way around. I want to be able to rotate my tires and get more than 15 to 20 thousand miles out of them.
Old 04-19-2015, 09:26 PM
W57thNY's Avatar
2013 Mercedes-Benz C250, Iridium Silver Metallic; 2001 Mercedes-Benz C240, Brilliant Silver Metallic
If stratman went with 4 wheels, and tires of the same size, and was able to rotate, wouldn't the handling get messed up, as the car's suspension is calibrated to work with staggered wheels?
Old 04-20-2015, 12:44 PM
jpbenz's Avatar
2012 300c, Lancia Zagato
I was wondering the same thing. I have a set of 17 all same size with snows
Old 04-20-2015, 01:01 PM
Skyline45's Avatar
2016 GLE450 AMG Coupe
Got all matching tires and wheels on my car. However, I have the Luxury version were this is by design.
Old 04-20-2015, 03:52 PM
TheRulesLawyer's Avatar
C350
I worry much less about suspension than the brake bias. When I went to non-staggered tires for my snows I noticed that the rear wanted to come around under hard braking more easily. Could have been the tires in general, but going to a smaller rear tire would cause a similar thing if they have the brake bias set assuming larger rear tires.
Old 04-21-2015, 06:52 PM
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
I have all four tires the same size but for the stance look I have 10mm in the front and 20mm spacers in the rear. When I do a tire rotation, just leave the spacers and move the tires. Simple.
Old 04-27-2015, 10:53 AM
Those of you who may have gone 225-45-17 all around. What PSI did you end up running on the tires? Thank you
Quick Reply: Why not use the same size tires all around?
