Bought OEM Wheels w/ TPMS, but Car Not Detecting TPMS
Old Aug 18, 2013 | 12:12 AM
Utishi's Avatar
C250
Hi Everyone,
I bought replacement OEM wheels that are 100% due to getting a small accident and having to replace my OEM rims. The wheels I bought came off a stock car and has TPMS. However, when I installed the wheel back, my car couldn't detect the TPMS. Do i have to reset it or something so that the car will detect the sensors?
I remember taking off my OEM wheels and putting them back on. I didnt have to reset anything...
Thank You
Old Aug 18, 2013 | 12:29 AM
Utishi's Avatar
C250
I just read that if i have a new TPMS, i have to go to the dealership so they can program it.
My question is, where can I check the sensor number so I can tell my dealer? Would I have to remove the tire from the rim?
Old Aug 18, 2013 | 03:50 AM
dolvio's Avatar
2010 C250 4Matic
Did you reset your TPMS?
Old Aug 18, 2013 | 11:21 AM
djejglk's Avatar
2013 C250 sport
Maybe if it's a NEW TPMS, they have to be reprogrammed.
Off subject a little bit....what about when you rotate your tires? Do the TPMS smartly follow new positions?
Also...what if I go to discount tire and they can't figure out how to lock the TPMS back in (assuming I reuse the existing ones currently in the old tires). Is the dealership gonna charge me to reprogram it? That would suck.
Old Aug 18, 2013 | 01:54 PM
dolvio's Avatar
2010 C250 4Matic
Try going into your dash settings using your steering wheel buttons. Go to Setting and TPMS and reset everything. May work, may not.
Old Aug 18, 2013 | 02:08 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Hi Everyone,
Thank You
Could be the TPMS modules on the wheels you bought are not the correct ones for your car. Could also be that the TPMS modules on the wheels you bought are not working for some reason. (e.g. dead batteries).
In general, TPMS is not position sensitive. As long as the sensors are working correctly and are the correct ones for your car, you should not have to change anything when you remove & replace or rotate the tires.
AFAIK the TPMS reset function accessed through the system menu changes the default tire pressures used by the system to issue alerts - it does not reset the TPMS system.
Old Aug 18, 2013 | 02:58 PM
djejglk's Avatar
2013 C250 sport
Yeah, it seems the system should be pretty intuitive. I wouldn't think MB would require a TPMS/dealership visit EVERYTIME you rotate tires. That would be a true hassle. Besides, I'm sure most people don't visit the dealership just to rotate the tires, since it's a process that should technically occur about twice as frequent than any other required maintenance. Discount tire, as wells as others I'm sure, are probably used to this sort of thing (dealing with TPMS and such), so maybe the TPMS's are defective.
If anything, maybe the TPMS have a certain identity that correlates with the car it's on, and if that changes, then a re association (probably a one time deal) may need to occur. If one changes the tires, I'm assuming the TPMS that came with the car is reused, so the car stays happy until the TPMS's physically change.
Old Aug 19, 2013 | 10:48 AM
TitanTPMS's Avatar
Former Vendor of MBWorld
TITANTPMS
Here is how to reset your TPMS for NEW sensors ID's and/or resetting Air Pressure.
If this doesn't work you may have 1 or more bad sensors or the wrong sensors for your fitment. Do you know what YEAR MAKE MODEL the TPMS came off. I can check if have or know that info. What is your YEAR MAKE MODEL? If you do have the correct sensor and 1 is bad the system will not learn until you replace the bad sensor. You can go to any tire shop and have the sensors scanned to see which one is not transmitting.
TPMS life span is only 5-7 years
RESET Air Pressure
1 Inflate all tires to pressure listed on tire placard.
2. Turn ignition to ON position (engine off).
3. Press forward/back button on steering wheel until trip and odometer are displayed.
4. Press UP/DOWN button until tire inflation pressure monitor is displayed
5. Hold down reset button (located on instrument cluster) until MONITOR CURRENT TIRE PRESSURE? Is displayed.
6. Press + button TIRE PRESS, MONITOR ACTIVATED-PRESS. DISPLAY AFTER DRIVING A FEW MINS. is displayed.
7. If REACTIVATE-TIRE PRESS. MONITOR! Appears, repeat relearn procedure.
8. If CHECK TIRES! appears, indicates tire pressure too low, adjust pressures accordingly
Relearn New Sensor Ids.
Ensure all tires are inflated to the pressure listed on the tire placard. Vehicle must be driven for at least 10 minutes, while maintaining speed above 15 mph in order for system to learn new sensor IDs. If spare tire sensor ID is being programmed, a properly formatted scan tool is necessary.
Old Sep 18, 2016 | 10:41 PM
BBB78's Avatar
W212
RESET Air Pressure
I tried this on my 15' W212 with no luck. I just installed new wheels and brand new OEM TPMS.
Does this probably mean that the new sensors need to be scanned?
Old Sep 20, 2016 | 09:01 PM
intrdrgn's Avatar
2010 Mercedes C300 Sport
I just had my wheels replace & had the original TPMS from my factory rims install into the new ones my mechanic reset mines & works like a charm.
Old Sep 20, 2016 | 10:14 PM
BBB78's Avatar
W212
I'll have to make a trip down the hill then. Thanks
Old Jan 3, 2017 | 10:25 PM
mitjaypat's Avatar
2008 GL550 Polar White, 2014 E550 4matic Designo Diamond White Metallic
BBB78, what did you end up doing? I have a 2014 E550 W212 and I just purchased 4 brand new Schrader OE replacement TPMS sensors to put into my new wheels.
Old Jan 3, 2017 | 10:31 PM
BBB78's Avatar
W212
Any good tire place can program the tpms in less than 10 min.
Thats what I did.
Old Jan 3, 2017 | 10:34 PM
mitjaypat's Avatar
Thanks, BBB78. I hope to get them on in a few days.
