HELP! COMAND stuck in update mode!
Old Aug 30, 2013 | 02:15 PM
KCaudell's Avatar
2016 C300 4Matic Sport
I inadvertently mashed Update in an engineering menu and my system won't move off the error screen of unable to locate update disc.
The screen says remove disc and press CCE. I've literally pressed C, then C, then E; but to no avail. What is CCE?
How do I get the system to reboot at this point or did the system erase the firmware in preparation for the new software?
What can I do? I know... bone head move, but it's done.
Thanks.
K
Attached Thumbnails HELP! COMAND stuck in update mode!-updateerrordisplay.jpg
Old Aug 30, 2013 | 02:45 PM
irod's Avatar
2010 Mercedes-Benz C300 Sport
Just turn it off and come back in 10 minutes. That's what I did.
Old Aug 30, 2013 | 02:47 PM
KCaudell's Avatar
Not even overnight. I'm thinking about disconnecting the battery to see if that does it.
Thanks though.
Old Aug 30, 2013 | 02:56 PM
stosoorok's Avatar
w211, s204
I was stuck in Diagnostic mode, disconnected the battery and everything returned to normal.
Old Aug 31, 2013 | 07:58 AM
KCaudell's Avatar
Got it. I did disconnect the battery for 30 minutes and that didn't solve the problem. What did solve the problem was removing the PCMCIA card and then restarting.
Old Sep 1, 2013 | 02:05 AM
irod's Avatar
Oh that's interesting. I didn't have a card in when I got stuck so turning off the car for a while did it. Good to know!
Old Oct 1, 2013 | 09:15 AM
brigill123's Avatar
C320 CDI Elegance
When you say remove the PCMCIA card and restarting what did you mean by restarting? because I removed the card, switched off the ignition, locked the car and went back after 20 minutes and it was still stuck in 'remove disc and press CCE'
Old Oct 2, 2013 | 04:21 PM
KCaudell's Avatar
I shut the car off and waited for about 5 minute and restarted. I believe the software was looking for an upgrade disc in the CD, then the PCMCIA card. Since there was no CD in slot 1, it looked for a file on the PCMCIA and since it wasn't there it simply kept trying. Once removed, all was well.
K
Old Nov 6, 2014 | 01:42 AM
Rsuryana's Avatar
Mercedes-Benz E550
Force shutdown to exit update mode
You don't need to disconnect the battery. You can do the force shutdown by holding the power 'on' button until it powered off similar to any laptop. You will hear the harddrive click and stopped spinning immediately. Don't forget to eject the pcmcia and disconnect the media interface (iPod) before you do the force shutdown.
