Satin Black vs Flat Black Headlight Housing
Old Sep 9, 2013 | 11:04 PM
Chuey's Avatar
C300
Hello,
I recently blacked out my headlights and am pretty happy with the results. It makes for a much meaner front end, but I think I went with the wrong color. I chose satin black because I saw quite a few people on here using that, but I think its a bit shiny. I'm thinking of redoing and using flat black and was wondering if anyone has used that instead and have. I plan on using Krylon Fusion. I would like to produce something close to what Mikonuj does. I can't tell what type of paint he uses, but it looks a bit like flat black? Anywho, any help is appreciated!
Mikonuj Headlight
http://www.mikonuj.com/MikonuJ/Galle...rb23lb.html#32
Old Sep 9, 2013 | 11:14 PM
mmike's Avatar
'10 C300
he did my headlights and they look great. try emailing him to get the specifics on what he uses
https://mbworld.org/forums/c-class-w...-services.html
Old Sep 9, 2013 | 11:19 PM
Chuey's Avatar
C300
Thanks! Will do!
Old Sep 10, 2013 | 12:34 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
If you don't mind me asking, what's the ballpark figure for doing this?
Old Sep 10, 2013 | 01:46 PM
mmike's Avatar
'10 C300
By yourself or by a professional like Juno? I'd highly recommend taking it to Juno if youre not experienced. He had a W204 and worked on many W204 cars including my own. He knows the proper steps to doing it. It makes a big difference. You can see how it makes the front end much more aggressive. Heres my car
Old Sep 10, 2013 | 02:55 PM
C230Kompressed's Avatar
I drive what I drive
DIY -
1. Remove headlights and all screws holding it together
2. Put in oven at 200degrees for 10 minutes (one headlight at a time on a cooking pan; use bakers gloves)
3. Pry the silicone apart and pull the lense away from eachother with a flat head screwdriver
4. Paint the inside; use painters tape and be very precise
5. Put it back together loosely with some new silicone
6. Put it back in the oven at 200degrees for 5 minutes
7. Take it out and push it completly together, including screwing in any screws or clips that hold the lense together.
8. Put it back in the oven at 200 degrees for another 5 minutes.
Final- Re-install on your car and drool all night. This is about 2-3 hour process depending how long it takes you to paint and prep. Silicone $5, one spray can $5
Old Sep 10, 2013 | 03:19 PM
Doa's Avatar
Doa
W205
Originally Posted by C230Kompressed
DIY -
easy to **** it up though
Old Sep 10, 2013 | 03:46 PM
I think the worst is painting inside of the lense. You have to be very patient, and make sure to tape up the whole area you don't want touched with paint. Also it is very important not to leave any finger prints; wear gloves......Everything else is a piece of cake.
Old Sep 11, 2013 | 02:00 AM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
mikonuj did the work for me, it was flat black..great work, nice guy! he is located in the downtown la area
