Transfer Caes Leaking - $800 to fix ??
Two months ago, I bought my car in for wheels alignment for $99 and end with a bill for $1400 for replacements of Transmission Conductor Plate ($800) and Valve Body ($500). I have most of the required maintenance done at the dealership, including "transmission flush" and now it's the transfer case leak?? What will be next? Transfer case replaces??
Is $800 for the transfer case "seal" replace worth the shot? Or should I wait or take the hit and have the transfer case change at the same time??
Please help....
Thank you.
Your situation is tough to say, you've already paid in a good amount towards the transmission, that'll put you at over $2000 and the transmission is suspect at this point....I would talk to the SA if you're out of warranty about Mercedes goodwill assistance with labor, and maybe check with an independent about a transfer case rebuild, there's some good ones in southeast PA.
I've not seen anyone get a "repaired" transfer case. It requires replacement of the transmission.
Do all 4MATICS (E and S and ML) have the same design as C with the Transfer Case internal to transmission?
Someone was asking about a CPO 2012 4Matic on here. Did MB make any running changes to 4MATIC system in W204, or are they all faulty?
How many miles did you put on your c300. I had 81K miles on there. Keep us post-it.
After I got the Valve Body and Transmission Conductor Plate I thought about: What if this was all cause by we play around with the "manual-shifting."??
Did anyone done this and then the issue arise?
I than took it to a local mechanic and he said that the seal is only wet but not leaking, than just had it serviced at 60k miles last week, and the SA said that everything on my car is fine, (i didnt tell him what they said before)
I guess just get diffrent opinions on your leak, before you dish out that type of money. If its a leak your just replacing the seal which will cost you less than 50$ its the labor that they rape you with.
Thank you.
Please help....
Thank you.
