Coupe front seats into a sedan? Possible?
MB C350 CGI AMG -2008
Hello! I have a question, is it possible fit the w294 coupe seats into a sedan? And if so has anybody done it? Maybe show some pictures?
THAXXXX!
THAXXXX!
The Coupe seats might fit, but the rails might be different. The Coupe passenger seat has a manual slide and is not full power adjustable. I'm not sure I'd want the non-functional seat controls on the door if your car has them.
Sorry i ment w204. And yes I do have the functions on the door, but I've seen that there are coupes that also has it on the door. That's why I thought that it might work. Thax
Little confused
But if the coupe has fully electrical seats, does the seats still have manual slide under it? No ofcourse I don't want it if I something doesn't work properly. Thad for your respond!
I believe the seats from the C63 Coupe are Full-Power but last time someone looked a C63 seats- they were in the $3-$4K EACH Price Range.
Since the sports seats in the sedan with the sport+ package look lie te coupes it may be possible. Check the part numbers. If they don't work what about ordering e seats from the sedan that are offered?
Super Moderator
The standard Coupe is available with fully automated seats on both sides.
The seats in the C250/C350 Sedans with the Sport PLUS package look like the standard Sedan seats but are Black MB-Tex upholstery with DINAMICA inserts and Red Stitching. The Coupe Seats are completely different style.
I was wondering because I just bought a c 350 with amg sport pack and I have the leather seats which I just scratched with my jacket. It's quite bad.
So I have this friend that works in a place where damaged cars come in and they sell only in parts. I get it very cheap same price for every seats doesn't matter if it Renault Clio or Mercedes amg seats. That's why I asked, so I know what to tell my friend to look out for.
THAX
THAX
Super Moderator
Yes it is possible
Yes today I did fit a set of 2012 w204 coupe seats into my w204 saloon well worth the hassle my drivers seat was ripped so thought better to upgrade u need to find a set with same plugs and controls on the seats if yours are on the seats . Remove old seats then plug wording into seats the seat belt you remove from your old seats . There is no seat belt holder on coupe seats but luckily there is a bolt hols at end of the seat runner I just took a bolt from my old seat the one next to the seat belt bolt and it fitted great when tightening the belt onto runner make sure it's straight or seat will go back and jam I used a flat screwdriver to hold it while I tightened it into place I will add pics I also had to get the airbag light reset from my friend everything works fine electric seat heated seat no faults Defo a brilliant upgrade need any help just ask john
This is the seat belt that comes off the old seat the bolt to the top left I used to fix belt to new coupe seats
Old seats that where ripped
Bland bolt hole I fixed belts to here with bolts from old seats
Use this bolt to fix belts
Finished seats so much better
The plug on far right was left empty I did not have a plug for this
can you post more pictures?
