Oil Changes
Old Nov 12, 2013 | 02:10 AM
mac911's Avatar
C300 Sport/Palladium Silver on Black/P2
Originally Posted by JWH321
I'm a belt and suspenders guy from Missouri so I have to check everything 42 times.
I have a RWD C300 (W204). It uses 8.5 quarts of oil.
Am I correct in my assumption that I can pump MOSTLY ALL of its oil out using a "straw" sent down through the dip-stick tube? In other words, given that I do not have a 4-Matic car, the little fitting that seals to the top of the dip stick tube is NOT a requirement. For the last time, am I correct?
Yes, you can suck the oil out. I use the Mityvac plus. Works fine enough. Just be careful how much you put back in.
However, I do not know what you mean about the fitting that seals to the top of dipstick tube? You mean does it need to seal while sucking it out? No, because as long as the tubing is in liquid, like a straw, it will come out.
I recommend you use an approved oil though, like Mobil 1 0w40. Plus, the genuine filter, or the Mann equivalent (same filter).
Old Nov 12, 2013 | 07:48 AM
Glyn M Ruck's Avatar
Super Moderator
Mac ~ some of the dealer evacuation systems seal the dipstick tube when evacuating oil. This is supposed to be superior when draining 4Matics with their sump configuration to accommodate the front driveshaft.
Not necessary when draining non 4Matics & you will get most of the oil out if you loosen the filter & allow adequate drain back to sump time from the top of the engine.
Old Nov 12, 2013 | 08:29 AM
JWH321's Avatar
2008 C300 Luxury
Mac and Glyn, thank you -- My confidence will improve after I've done it a few times. In the meantime, it is VERY helpful to have folks like yourselves to fall back on to be sure that I don't screw up my car. I try very hard to be sure it is always in perfect order, but with the world the way it is economically, its always good to be as self-sufficient as possible (or, as my wife says, I gotta get cheaper with my hobbies).
My late father drove his last Mercedes nearly 500K miles (240D). I'm going to try to get close with my C300.
Old Nov 12, 2013 | 09:37 AM
Super Moderator
As long as you are methodical you will have no issues at all. Seems you are a methodical person so you have nothing to worry about.
