Got a wirling sound
Old 02-14-2014, 11:14 PM
MBc300elvis's Avatar
C300
Got a wirling sound
2008 c300 it's killing me when I press on the gas low rpm it makes this wirling sound idk if I can hear it from the outside but it's not the steering positive,thought it would go away nothing yet owned it for 6 months now
Don't know what to do someone help what could it be??
Old 02-14-2014, 11:34 PM
w204_Generic's Avatar
2011 C300 4Matic Sport
That could be the air intake you are hearing. Low speed so there is no wind and you hear it more.
Old 02-15-2014, 12:57 AM
Super Moderator
Glyn M Ruck's Avatar
It could be the transmission oil pump. Can you hear it stationary in neutral or park? It could also be the poly V belt tensioner or idlers.
Old 02-15-2014, 06:10 PM
C300
Not that already replaced it good idea though
Old 02-15-2014, 06:13 PM
C300
When I rev it it gets wirly on drive neutral and park. thanks for the idea I've got an appointment for a software issue gonna take it to mercedez see what they think.
Old 02-15-2014, 07:51 PM
JohnnyC300's Avatar
2009 C300 Sport 4Matic
Similarly, I noticed that when using the suggested gear ranges of D1 and D2 the engine exhaust note sounded much more high pitched and whiny as opposed to its usually deep robust sound. Is this potentially also the transmission oil pump/poly V belt/tensioner/idlers?
Old 02-16-2014, 07:45 AM
Super Moderator
It sounds as though it could be the transmission oil pump you are hearing. It is a little variable unit to unit & is normal. Benz redesigned & changed to an aluminium pump to reduce noise but it's still there.
Old 02-16-2014, 08:41 AM
C300
Yea I'll probaly have to deal with it till I trade in next year ... Do you guys have it in your cars at all? Or ever hear it in a friends car or somthing?
Old 02-16-2014, 02:05 PM
Rodpwnz's Avatar
C300 sport
I hear it in lower gears, 1 and 2. Whenever I drive through my university parking structure it is very noticeable. Like Glyn said, I assume it is normal. I feel like manual transmission and more sport oriented cars such as BMW don't have the same noise whine.
Old 02-16-2014, 10:07 PM
C300
Yea it gets to me a lot. gotta blast the radio to ignore it lol
Old 02-17-2014, 07:11 AM
gmphertford's Avatar
S Class
If diesel possible turbo noise, transmission will not make noise if in park.
Old 02-17-2014, 08:07 AM
Super Moderator
The transmission pump does make a noise in Park. It runs continuously at input shaft speed with engine running.
Old 02-17-2014, 10:55 PM
C300
Not diesel and transmission pump sounds like it mostly
Old 02-18-2014, 06:26 AM
Super Moderator
On some older 722.9 transmissions the pump actually makes the most noise on start up in Park. You get a bit of a roar out of the pump until pressure normalises in the transmission & then it quietens down.
Old 02-18-2014, 03:01 PM
C300
Yea exactly I hate that certain noise though sucks
Old 02-18-2014, 06:23 PM
Super Moderator
Even the old 722.6 5 speed did it. It's just a Benz noise you get used to. If it gets really loud it can be sign of a failing torque converter but I mean really loud.
Old 02-19-2014, 09:28 AM
C300
It's really not that loud just annoying honestly lol
Old 02-19-2014, 09:31 AM
Super Moderator
The TC makes a deafening howl when the bearings fail.
Old 02-19-2014, 05:13 PM
C300
Nah that's deff not it
Old 02-20-2014, 07:40 AM
95_993's Avatar
C300 Sport
I have noticed a slight hum of the pump at low speeds when there is not much road noise. Immediately knew it was transmission as it has a very distinct sound.
Glad to hear from Glyn that this hum is likely normal is a known characteristic of this transmission. I am still getting acclimated to the feel and sounds of this car as I have only had it a couple weeks.
Old 02-20-2014, 09:10 AM
C300
Originally Posted by 95_993
I have noticed a slight hum of the pump at low speeds when there is not much road noise. Immediately knew it was transmission as it has a very distinct sound. Glad to hear from Glyn that this hum is likely normal is a known characteristic of this transmission. I am still getting acclimated to the feel and sounds of this car as I have only had it a couple weeks.
Yea I'm trying to get used to it. Blast the radio it helps lol
Old 02-20-2014, 09:31 AM
Super Moderator
This has been a characteristic of Benz cars for a long time.
722.9 oil pump
Old 02-26-2014, 06:09 PM
julianmousa's Avatar
Mercedes C200 CGI 2011 W204
Got the same problem, anything new -what can it be?
Old 02-26-2014, 09:01 PM
C300
Nah bro it's killing me I had a loaner two days ago same car just 2014 so quiet I was jelous brother in law is a mechanic said just how 2008"s are
Old 08-13-2015, 01:24 PM
nycrx7's Avatar
C250
Sorry to rehash an old topic...
but does the whining sound... is that like an electric motor from a R/C car? I picked up 2012 C250, and when I am starting off, I can definitely hear that sound. Was curious if this was the sound everyone else heard.
Thank you
Quick Reply: Got a wirling sound
