Roof rails are peeling... What is the best way to fix them?
Old Feb 28, 2014 | 12:49 PM
hdsalinas's Avatar
C220
The "clear coat" on the black plastic roof rails is peeling bad. I was thinking of masking, sanding and spray painting them. Is there a better solution?
BTW. I read somewhere that this "clear coat film" is actually a plastic protector that the dealer did not remove when new and that with the effects of time and the elements, has baked into the rails. Could this be true?
Old Feb 28, 2014 | 03:00 PM
2012C250's Avatar
2012 Mercedes C250
If you have warranty your dealership can replace it.
Old Feb 28, 2014 | 03:42 PM
W204white2010's Avatar
W204
I just had mine replaced under warranty after almost 4 years of ownership too.
Old Feb 28, 2014 | 03:48 PM
xXHotelCrazyXx's Avatar
2008 W204 Sport
I painted mine myself, they were starting to peel. They are removed very easily. Just start from the very front and pull up with your hands and fingers with a firm grip and firm force, and they will unsnap at each point as you work your way back.
Old Mar 1, 2014 | 08:14 AM
JWH321's Avatar
2008 C300 Luxury
Would Plastic dip be a better choice for repair?
Old Mar 1, 2014 | 09:30 AM
2008 W204 Sport
That's what I used.
Old Mar 1, 2014 | 09:42 AM
JWH321's Avatar
2008 C300 Luxury
Thanks. Mine just started it this week around where the Thule bike rack sits.
Old Mar 2, 2014 | 08:30 AM
RickP330's Avatar
2019 GLA 250 - I am in purgatory right now...
how much do they cost to replace? Anyone have any part numbers? I have this problem too...
RP
Old Mar 2, 2014 | 09:12 AM
||||||||||'s Avatar
2009 Mercedes C350
RP
More than it is worth. Like hundreds.
For what it's worth, I removed mine and painted them as well, and though it looks better, I'm not really pleased with the results.
I took the time to sand them, clean them, prime them, base coat and clear coat them, and you can still see marks through the paint from where the clear coat was still left and where it was peeled off from the elements. Perhaps if I did a better job sanding it wouldn't be noticeable.
From a few feet away it looks fine, and unless the sun is shining on them you will never notice, but up close, they don't look so hot
Old Mar 2, 2014 | 09:52 AM
AkaSigFreak's Avatar
E350 Sport/ML350RWD
The clear layer isn't like a painted clearcoat- it is like a thin layer of clear vinyl. It will start to peal off. On my 2008- I had it replaced about a year in and then it happened again towards the end. The dealership tried to charge me the second time and I reminded them this was an ongoing issue. They admitted they saw this often and replaced them at no charge.
Old Mar 3, 2014 | 09:50 AM
JWH321's Avatar
2008 C300 Luxury
I have to fix it -- its ugly.
It looks to be about $300 for new ones for both sides. But it appears to be worth trying to repair it first, either with paint or Plastidip -- perhaps even a wrap. I'll try to document the fix. Knowing me, it'll probably be both. I'll repair it first, then after feeling unsatisfied for a week, I'll get new parts.
Old Mar 3, 2014 | 10:41 AM
||||||||||'s Avatar
2009 Mercedes C350
Some type of vinyl wrap would probably be easier. Unless you're going to spend hours on the prep work, Id bet you won't be satisfied with the results painting it.
http://www.ebay.com/itm/2-X-10-FEET-CARBON-FIBER-STRIP-BLACK-VINYL-WRAP-GRADE-BUBBLE-FREE-3D/131131263840?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D163%26meid%3D5226873720068161371%26pid%3D100005%26prg%3D1088%26rk%3D1%26rkt%3D4%26sd%3D161239569729%26
Not sure how you feel about the fake Carbon Fiber look (I personally don't like fake CF) but something similar to what I linked to should work for you. I may try it myself if I can find some regular flat black in that size for cheap.
EDIT:
http://www.ebay.com/itm/Black-Sign-Vinyl-12-x-10-feet-/130508730611?pt=LH_DefaultDomain_0&hash=item1e62ed30f3
This is what I would buy, and it's only $14.00. Not sure how well it would adhere, look and hold up. Maybe someone else can chime in on that?
Old Mar 3, 2014 | 10:57 AM
E350 Sport/ML350RWD
If it wasn't covered by warranty- I would do the vinyl wrap like recommended by ||||||||||||. Follow the instructions for removal and wrap them. You might still be able to see remnants of the sections that have peeled, but it should not be that noticeable.
Old Mar 3, 2014 | 11:17 AM
Glyn M Ruck's Avatar
Super Moderator
Are these South African built cars that are suffering this problem? I'm interested as we do so much harsh UV testing here.
Old Mar 3, 2014 | 11:32 AM
JWH321's Avatar
2008 C300 Luxury
Nope -- its a Bremen car. Strange since everything else is holding up perfectly. But I'm in central Florida, US and the sun is pretty intense here.
It started as bubbling around the roof rack attachment points, and I thought perhaps it was caused by the feet on my Thule rack, but now the back end of the strip is peeling exactly like the protective covering on a piece if silver or an electronic screen. At first I thought, silly me, I just forgot to peel this off. Its clearly a clear covering of some sort.
Old Mar 3, 2014 | 11:55 AM
||||||||||'s Avatar
2009 Mercedes C350
SA built here, and mine were peeling BAD when I got the car. It was mostly a southern Louisiana car it's entire life, so I'm not sure if humidity/heat are a factor.
Unfortunately I am out of warranty, and even if I weren't, I suspect the same thing would happen in a couple years if they were replaced
Old Mar 3, 2014 | 02:34 PM
Super Moderator
If it's happening on all cars it must be an international part from one supplier. We had no trouble on our 2 family W204's. Must keep my eyes open here & see how common it is.
Old Mar 3, 2014 | 06:11 PM
JWH321's Avatar
2008 C300 Luxury
Glyn
Here are some quick cell-phone photos of the damaged areas -- sorry the car is so dirty.
Attached Thumbnails Roof rails are peeling... What is the best way to fix them?-img_0037.jpg   Roof rails are peeling... What is the best way to fix them?-img_0039.jpg   Roof rails are peeling... What is the best way to fix them?-img_0040.jpg
Old Mar 3, 2014 | 06:16 PM
Super Moderator
Wow. Those things on my old W203 that is now with a friend are like new still.
Old Mar 3, 2014 | 06:40 PM
JWH321's Avatar
2008 C300 Luxury
Oh, yes. The same on some of our older cars, too. And on this one, its mostly on one side of the car. There is a bit on the right side, but the large parts are on the left side.
The car looks like its scratched in the photos -- it isn't. That's what rain and tree pollen do down here. The paint remains perfect. This car has endured high altitude -- 14K feet in Colorado, extreme cold -- negative 33 degrees F in Lake Placid, and day after day of extreme heat in Florida and AZ. the only issue is with the roof trim. But I still want to fix it. Almost perfect is imperfect.
Old Apr 12, 2014 | 01:20 PM
ofromesyahoocom's Avatar
2010 C350 Black Sport
ROOF RAILS
MINE ARE PEELING TOO
Old Apr 12, 2014 | 01:31 PM
DID YOU FIX IT??
Glyn
MINE IS EXACTLY THE SAME
Old Apr 12, 2014 | 07:27 PM
Mikephinney's Avatar
2012 C250
Mine as well, took it to the dealer and was told that the previous owner probably had a rack on it. So no luck. Went in for a different service and was put in a loaner, same thing on the loaner! Guess who ever had it on loan put a rack on it for a day, right?
Old Apr 16, 2014 | 02:34 PM
JWH321's Avatar
2008 C300 Luxury
Mine is peeling at the rear, well away from the areas touched by a rack -- just above the rear window. I talked briefly with the Service Advisor. He says they have never seen that before. The parts guy tells me that they keep the strips in stock because they are replaced often on Certified Pre-Owned cars before they go to the lot.
Its frustrating to not be able to find an honest man in the car repair business.
I have a set on order. I'll post a short "how-to" if I'm successful in fixing it.
Old Apr 16, 2014 | 02:54 PM
THANKS, I POPPED THE 2 RACKS OFF STARTING FROM FRONT TO BACK. AND I BOUGHT SOME PLASTI DIP FROM HOME DEPOT FOR $5 DOLLARS A CAN. SANDED DOWN THE OLD PAINT AND CLEAR COAT AND SPRAYED IT WITH 5 LAYERS OF PLASTI DIP !! LOOKS GREAT. MB SHOULD NOT HAVE PAINTED THESE PARTS AT ALL SHOULD HAVE JUST LEFT THE OG BLACK PLASTIC COLOR. P.S. I ALSO PLASTI DIPPED MY FRONT GRILL BLACK BUT LEAVING THE MB LOGO CHROME. I'M SATISFIED WITH THE JOB. NOW I JUST HAVE TO BUY THIS MITIVAC OIL CHANGE PUMP SO I COULD DO MY OWN OIL CHANGES. I'M NOT GOING TO SPEND $150 AT THE DEALER FOR A OIL CHANGE THANKS!!
