Hubcentric Rings
Old Mar 4, 2014 | 05:04 PM
2012C250's Avatar
2012 Mercedes C250
Hubcentric Rings
Anyone know where i can get an aluminum hub centric ring.
ID: 66.6 OD: 60.1
I've only come across ID:60.1 OD:66.6. Thanks in advance.
Old Mar 4, 2014 | 05:10 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
Try Summit Racing
Old Mar 4, 2014 | 05:19 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Discount tire or most any tire shop should have them or be able to get them easily enough.
Old Mar 4, 2014 | 10:22 PM
2012C250's Avatar
2012 Mercedes C250
Originally Posted by Nanook
Try Summit Racing
I check those sites already but they don't carry ID 66.6 OD 60.1
Old Mar 4, 2014 | 10:29 PM
chrisridebike8's Avatar
'10 C63
I don't think you are making sense. If your wheel is 60.1 (OD) and your hub is 66.6 (ID), then you need to machine your wheel (ie-drill the hole bigger). I am not sure how safe that is. I am assuming ID means inner diameter and OD means outer diameter. That would be the reason you have only found the one type of ring. Or someone tell me if I'm taking crazy pills...
Old Mar 4, 2014 | 10:35 PM
Nanook's Avatar
I've used this guy to make me custom rings and spacers. Ian will machine you what ever you need..
http://www.novustech.ca/
2012C250's Avatar
2012 Mercedes C250
Yes that is what i mean. I'd prefer to get hub centric rings instead of drilling the hole bigger.
Old Mar 4, 2014 | 10:38 PM
Peydidy's Avatar
C63 AMG
Thats not how it works.
If the hub of the wheel is BIGGER then your cars hub you use rings.
If the hub of the wheel is SMALLER then your cars hub then you don't have the option of using rings considering rings don't magically change the size of your hub, they are just filling the extra room.
Old Mar 4, 2014 | 10:42 PM
2012C250's Avatar
2012 Mercedes C250
Oh dam, i guess i have to redrill the hub on the wheels
Old Mar 5, 2014 | 07:04 AM
'10 C63
The only way it might work is if you ran spacers that had some sort of adapter that stepped the hub bore down. But I don't even know if they make those. And I don't know how much clearance you have to run spacers.
Old Mar 5, 2014 | 08:59 AM
Nanook's Avatar
The guy I sent you will machine spacers or whatever you need
Old Mar 5, 2014 | 09:26 AM
Glyn M Ruck's Avatar
Super Moderator
By far the best way to fix this problem is to increase the wheel's pilot hole diameter to 66.6
Old Mar 5, 2014 | 10:00 AM
'10 C63
You sure about that? If the company makes that wheel with a 66.6 hub bore, then I don't see a problem. But then why doesn't the OP just buy those then? 3.25 mm machined from the hub seems like a good chunk of metal to me. My engineering brain sees possible structural issues with that. Spacers that step down the size seem better.
Old Mar 5, 2014 | 10:13 AM
Super Moderator
I hear you, but most wheels will be made to be machined to fit to multiple hubs. You don't have to ream the entire pilot hole. Just sufficient to seat the wheels.
The more interfaces you have the better the chance of losing hubcentricity & vibration/run out.
Old Mar 5, 2014 | 12:55 PM
Doanster's Avatar
C300 Sport 6MT
True. I'd have no concerns/worries IF the wheels are re-bored at the "factory", i.e. completely setup with proper alignment jigs, etc.
Having "some guy" do it in his shop as he pulls out his collection of Harbor Freight key-hole drill bits and eyeballs where true-center is would have me worried.
Old Mar 5, 2014 | 06:57 PM
Super Moderator
Yes ~ If one is determined to try & mount the wrong wheels it needs to be professionally done.
Old May 18, 2019 | 12:33 AM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
Is there any disadvantage to using hub centric rings? I presume a hub centric wheel is the way to go but you're more limited?
